Which LNB | |
| Member Join Date: 03-06-2006 Location: Essex uk
My System: Amstrad RDX300 |
I have done a search but maybe I havent entered the right info so.... I am confused as to what is the better LNB rating. 0.3dB or 0.2dB I will be using an 80cm dish in North West France, Pays De La Loire and just want Brit TV, FTV. Thanks fred | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The lower the better, but the very low ones cannot be trusted as being totally factual. Any reasonable LNB with an 80cm dish will be fine for all of the UK channels on Astra 28.2E in the Loire region.
__________________ | |||
| What me worry? Join Date: 08-01-2005 Location: Southern Ireland / SW France
My System: PACE 430 (Radio Reception only to feed a SKY Gnome), PACE 3100 (PVR 2.5), ROI SKY 6 mixes, Technomate TM-1500 CI+, TM-6900 HD, 100 cm Triax (Sky), 80 cm Nokia with Motec SG-2100. MacBook and that's that. | I take in Sky with a 1 meter dish in Bergerac, fitted with a 0.6 dB LNB so you'll be more than fine with any odd LNB on a 80 cm dish
