Can I get some more satellites? | |
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! |
I've been playing with google earth and seem to have noticed that I may be able to get more than just Hispasat, so I'm attatching the pic I saved and modified for some smart people to have a look at and modify to show me what I can actually get (28.2e is out of the question as I'd have to be able to have my dish "seeing" over the roof and next door's chimney as my street is pinting between 25 and 30 degrees EoS...).
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | ||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | It's impossible to say that from a picture. You need to find out if there is a clear view to the sats from where your dish is. Then there is the issue of the dish size. If you could put up a 5m dish, you surely could get all sorts of stuff. But, if I was you I would try to find out if 30 west is in your sight, as this has been a sat with a lot of free stuff (not at the moment though). To do this, use a compass and have a look.
__________________ I only believe stuff that comes straight from Mr. Horses mouth | ||
| | #3 | |||
If I set a dish up upstairs, LOS wouldn't be much of a problem until the satellites get too far south.
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | oops sorry 2CV did not notice the 30 West. Just try it out and see what you get. If you have space to fit a motor then get yourself a SG1200 for 60 Euros and play with it...
| | #5 | ||
| Member Join Date: 14-04-2006 Location: Berkshire
My System: Technomate 5500DACPI, Lemon 80cm Mesh, Moteck 2100SG Lemon 0.2LNB.. | Depends if your set top box allows blind searching. If it does I would invest £25 in a decent satellite meter and start experimenting. (You'll most likely need the sat meter anyway to line up a motorised system.) Presume your dish is pole mounted so you can swing it around and make the elevation a bit (nudges) higher to aim for satellites further south. The meter will let you zoom in on the signals without undue stress. When you've found a signal of decent strength, get down to your tuner to see what you've found. I don't trust my compass, much prefer to use google earth to work out where the dish is pointing ... if no joy then resell the meter on FleaBay for a few quid less than you paid for it. I reckon you should be able to pick up a bit of French tv at least on Atlantic Bird 3 5W although virtually impossible to tell from your roof pic. Sadly no 2CV ads these days.. | ||
| | #6 | ||
| If your existing arc is correct you could start checking by nudging the dish either way in small amounts Blind search is only about three years old, but many people have been searching for satellites without the feature for years.
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| | #7 | |||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! |
| | #8 | |||
Also, Birdseye, I have a cheap beeper meter (as listed on the left which seems to be missed out often) which works very well for re-aligning my dish after my cat's swung on it (numpty!!!), but I haven't tried it on any other satellites yet... Also I don't have the money for a Blind Search receiver (yet) so all I have are my analogue boxes and my Digital Nokia and Porty boxes... But seeing how I'll probably be indoors most of the weekend I'll have a go at finding another satellite to watch, but I'm hoping (with a bit of luck) that I may be able to get 13e (minimum, 19e a possibility too) on a dish stuck outdoors, but whether I can have an outdoor dish or not is another matter (rented house you see)...
| | #9 | ||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | I have no idea why I didn't think of this earlier!!! I have potential access to 3 more satellites!!!! (see attatched image)
| | #10 | ||
My System: Technomate 5500DACPI, Lemon 80cm Mesh, Moteck 2100SG Lemon 0.2LNB.. | Okay you have all the kit you need. Just line up your dish pointing at whatever you can see on Google earth is in the right direction... bit of waggling with your dish until your meter bleeps a lot and then you should have something to look at. The blind search isn't necessary but it saves you going down to smiths and getting a copy of 'what satellite' so that you can program your STB with the right channels. Obviously if your dish ain't pointing at the satellite that you think it is then you won't catch the channels you think you're getting and you'll just get frustrated, even though the meter is giving you a good signal Good luck! | ||
| | #11 | |||
Anyway, once I can must up the botheredness, I'll be having a go with upside down and sidways mounting of my spare 60CM dish indoors for 5w...
| | #12 | ||
| Information Exec Join Date: 01-01-2000 Location: kent
My System: humax 5400z patched to hot 7.5, v box mrk2, 1.1m triax dish, jeager 12" activator .6 lnb, modified pet123 settings ![]() Le grand ordre d'arrangements de Humax | hi all, ok i give up, what have i got turned off, i am running firefox latest, but i am only seeing the placeholder for the thumbnail. thanks phill | ||
| | #13 | |||
| | #14 | ||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Ok, seeing how the Hotbird lot have got/are getting some new satellites set up, would my little Porty kit dish pull in a decent signal now?
| | #15 | |||
| Folding*home Join Date: 23-02-2006 Location: Madeira
My System: [ Relook 250S ] |
- 30W - 7W - 5W - 5E - 7E - 10E - 13E - 16E - 19,2E - 23,5E - 26E - 28,2E
__________________ ![]() When people ask me what I think, I tell them: "I think all of the meat around the pig's ass is pork." | |||
| | #16 | |||
), but I just want the 3 I pointed out, and as of today, I now have 2 dishes up!!! Well, indoors still, but I now have 5w aswell as 30w!!! There was one niggle when finding 5w, at first I picked up an encrypted analogue channel (which I later found to be Canal+) on 12606V, but I couldn't find anything else in analogue, so I swapped my LNB (humax .3dB) for my spare Humax (I have 2) thinking it was faulty, then switched the box on and waved the dish about and came across France5 on the exact same frequency!!! Then moving the dish a couple of degrees west I found Canal+ again, so I guess that was 7w, but it didn't half drive me up the wall!!! Anyway, the next problem to solve is why I couldn't get the FranceTV channels on either my Nokia or my porty, unless I just have outdated TP info... Next satellite: Hotbird!!! I've never managed to pick it up before so this'll be a first for me...
| | #17 | ||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | After a search through Lyngsat, it was 8w I was unwillingly picking up, but at least I now know it's easy to find!!!
| | #18 | ||
| Specialist Contributor Join Date: 16-01-2005 Location: Lancashire
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought. | if u need to go further west don't bother their is nowt in english but before hispa 5*e has a couple of channels at the mo it u can get it... I am an ex cb-er and what i learnt from my 80's cb days was you can do it just get a bloody big pole and go over the chimney and u will get the whole caboodle... | ||
| | #19 | |||
As for big poles on the chimney, it's a case of getting permission and getting up there....
