slight movement in motor arm | |
| Member Join Date: 25-02-2004 Location: n.ireland
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card |
i am trying to setup my system but cant seem to get the quality past 25% at the (rare) very best. i have noticed a slight movement in the motor arm which the dish attaches to is this normal or will it cause problems. it is a hh mount i am using capable of taking up to a 1.2 m dish mine is 1m | ||
| Make and model ? Not all manufacturers live up to the claims of the DiSEqC capabilty with dish size, and even fewer suppliers guarantees are worthy of the paper.
__________________ There is a very fine line between "hobby" and "mental illness" | ||
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card | it's a bigsat diseqc hh mount 100 - 120 but thats not the only strange thing ive noticed the declination table marking thingys on the dish go from 40 to 20 and the book says to take 40 minus the declination angle which in my case is 7.6 but when i set it to 32.5 the dish is tilted back quite a lot and the signals rubbish so if i tilt it forward to get the best signal its actually off the scale on the dish ive checked to see if its fitted back to front but its exactly how the instructions called for it to be fitted in fact its the only way the thing can be fitted. i have checked the latitude/elevation for the motor a hundred times and they are right so im completely stumped now | ||
| Nasty Dish Obsession Join Date: 01-06-2004 Location: Oxfordshire
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Pictures Pictures !!!! ![]() L.
__________________ I've got an inferiority complex, but it's not a very good one. | ||
| | #6 | ||
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card | here goes. gardens a bit messy but im working at it. just wondering if the hedges would be a problem but they are not much higher than the dish and about 3m away | ||
| | #7 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Hedges are OK, the 'look' angle is a lot higher than you think. The dish looks a bit high if you are trying for 5W. Not a lot, but it doesnt take much. What transponder are you trying to set up on ?? l.
| | #9 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | No it isn't the hedge. I aligned a similar dish the other day, what make is it? It struck me that the bracket looked to be upside down on it, but it had no mark to compare with the scale, normally the pivot bolt is at the top. The other fact I disliked about the dish, was that like a few other cheaper dishes, you need both hands to tighten the elevation bolts, so what are you supposed to use to move the dish, a small point, but very annoying when mounting a dish at height.
__________________ | |||
| | #10 | ||
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card | no trees its clear after the hedges as for the transponder im trying for atlantic bird 3 on 5.0w the signal is steady at 98% but the quality is fluctuating wildly between 3% - 25% | ||
| | #11 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Couldn't see the alignment mark on the dish. Is that it behind the bolt head Rolf ?? L.
| | #12 | ||
| Regular Member Join Date: 18-11-2004 Location: Belfast, Northern Ireland
My System: Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn. | Yes, tighting the dish with both hands can be havoc. I find some Triax dishes to behave like this. | ||
| | #13 | ||
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card | rolfw the dish you were setting sounds exactly like this one. the scale looks to be upside down with the pivot bolt in the bottom and you need 2 hands to tighten the bolts as for make i dont think it has one i'll check | ||
| | #14 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Is your reciever set to 11591 V S/R 20000. Try that. L.
| | #15 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I don't think that there is a mark on the bracket, I couldn't see one on the other dish, but then I was just there to line it up and as I managed it without any changes it didn't matter.
| | #16 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Thought this might be it, it would intersect the scale if the mount was the other way up. Whaddya think ??
| | #17 | ||
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card | if you look to the right of the bolt on the dish fixing bracket you will see the alignment mark but as i said to get the best signal i had to move it right of the scale the whole lot looks a bit screwed up. here is a picture of my screen in case that makes any difference. lancelot i will check what the receiver is set to in a few moments cause the missus is watching stupid big brother and when its on i cant get near the telly downstairs. what are those settings the firmware or something? | ||
| | #18 | ||
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card | yeah lancelot thats it do you mean the actual motor mount? | ||
| | #19 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | No - manual transponder settings/scan should be there on your menu somewhere mate. Or if you can look at the channels for a single satellite, then pick that transponder on AB3. L.
| | #20 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Que ?? what are we saying . L.
| | #21 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | It actually doesn't matter too much if the bracket is upside down, as long as the dish can be set at the right declination.
| | #22 | ||
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card | the dish bracket will definitely go on that way as for the mount i am assuming its meant to go the way ive put it although as these pics from the box and instruction book show i dont think the people who manufacture it have decided yet | ||
| | #23 | ||
My System: Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn. | The dish looks to be similar to a triax dish, the mount etc. Does the arm fold up?? | ||
| | #24 | ||
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card | no it goes through the dish and is bolted in at the back. they must have given me one of the aussie dishes. UPSIDE DOWN | ||
| | #25 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The Triax dish has a sliding method of adjustment, not pivot bolts, although the dish back plate does look slightly similar.. At fersy, wasn't questioning the motor bracket, but the dish bracket, as it is extremely unusual for the pivot not to be at the top. As I said in the earlier post though, it makes little difference, as long as the dish can be set to an appropriate declination. Are you 100% sure that you are on the correct satellite?
