Superjack DG-120
Thread Tools Display Modes
Old 03-07-2006   #1
My System: 80 cm motorised dish with SkyStar 2 and Pace Prima; Sky minidish and box
Superjack DG-120
After a while of working fine, for some reason all of the positions of my motor seem to have shifted east - again. It has definately not moved on the pole.
It would be nice if I could finally get this sorted once and for all
My motor is a Superjack DG-120, exactly the same as this. Can I ask anyone who knows about or has one of these motors, should it be able to go directly to angles, ie. circled in the first picture below? Mine (sort of) seems to but I would like to know for sure.
If I set my location to zero degrees west/east, and send the motor to zero degrees, it does not go to the zero marked on it - see the second picture below. Is this right? Surely it should be dead on?
If it does support angles, I'll have to turn it slightly on the pole, but at least it will be as it should be.
andy29 is offline   Reply With Quote
Old 03-07-2006   #2
rolfw's Avatar
Is 0 degrees your longitude?
Normally sending the motor to zero should do it, but if it doesn't, then sometimes you can do a reset with the buttons on the remote.
__________________
Rolf
Donate
Old 03-07-2006   #3
Thanks, no, I'm actually at -1.7 degrees. I just wanted to see what happened if I set everything back to zero. How would I reset it with the buttons? The manual doesn't say anything.
Old 03-07-2006   #4
rolfw's Avatar
Sorry, I meant to type "the buttons on the motor".
Not all motors can do this though.
Enter your longitude correctly in the receiver and it may go back to zero when you ask it.
If it doesn't, change to DiseqC 1.2 and manually take it to zero.
__________________
Rolf
Donate
Old 03-07-2006   #5
But no matter what I do, it never goes back to the zero marked on the motor.
How do you mean to take it to zero - move it to position zero, an then correct it with the buttons? Move it to zero degrees? Then do I save it as position zero?
Sorry, it's probably obvious, but I'm still a noob at this. Thanks for your help
Old 03-07-2006   #6
rolfw's Avatar
Does the motor have buttons on it?
__________________
Rolf
Donate
Old 03-07-2006   #7
Yes, two - move to east, move to west. No LEDs though.
Old 12-02-2007   #8
(Seven months later... )
I just tried a little something.
I set my longitude to 0 degrees. When sent to position 0, the dish moves to (very roughly) ten degrees west as marked physically on the motor. When sent to angle 0 degrees, it moves to the same place.
Then I set my longitude to 20 degrees east. Now when sent to position 0, it moves to the same place as before - but sending it to angle 0 moves it roughly twice as far west as before.
Makes sense to me. Angles, but not positions, should change with longitude, as the motor is calculating them (?). But it seems that the motor's position zero... is not zero! If your longitude is set to 0 degrees and you send the motor to 0 degrees, shouldn't it go to 0 degrees?
Old 12-02-2007   #9
rolfw's Avatar
You probably need to drive the motor with the buttons onboard to 0 on the motor scale, then if it has a small reset hole next to one of the buttons, reset it with a steel pin and reset your receiver.
__________________
Rolf
Donate
Old 12-02-2007   #10
Donate to this board
Park Royal's Avatar
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
The Jaegar Superjack DG-120 does not have the reset facility that the Motecks have. Just two buttons, drive east and drive west.
Drive the motor, via the receiver to zero. With a spirit level on the mounting stub drive the motor with the buttons until the mounting stub is dead upright. Then go back to your receiver and highlight re-calculate and press OK.
All should be correct from now on.
PR
Park Royal is offline   Reply With Quote
Old 13-02-2007   #11
Thanks, I did try that quickly today before it decided to rain, and it still refused to change. But I will try it properly if I can tomorrow
Just a thought though - could this be anything to do with the adjustment that can be made on the back of the motor?
Old 15-02-2007   #12
Thanks, but it still refuses to change
And I don't know what the adjustment on the back is for, it seems to do nothing.
For the moment I just set my position to 0 E/W and 0 N/S, then sent it to 0 degrees and position 0.
What you see on the left gives what you see on the right...
Why am I starting to get the feeling that the motor is faulty?
Old 15-02-2007   #13
Park Royal's Avatar
Sorry that it did not work for you, it did for me that's why I posted.
PR
[IMG] code is Off
Forum Jump
