TechniSat distribution system... | |
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! |
I was just looking at THIS system and was overwhelmed with a dim thought, as it has a V/UHF input, does that mean that you can hook up a normal TV to the output and get the normal terrestrial signal? If so, what do you do if you want a satellite box on there too?
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | ||
| Nasty Dish Obsession Join Date: 01-06-2004 Location: Oxfordshire
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Perhaps it upshifts the UHF to where the input of a normal sat reciever is looking so it can display DTT. L.
__________________ I've got an inferiority complex, but it's not a very good one. | ||
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | There are five inputs, four being the output from a Quattro LNB, the other being a Terrestrial UHF and VHF antenna. At the socket, all you need to do is install a diplexed or triplexed outlet. You can then run a satellite receiver, normal TV and VHF radio from each outlet point.
__________________ | |||
| | #4 | |||
![]() Told you I was overwhelmed with dimness....
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
