90cm Gibertini vs 100cm Golden Interstar | |
| Regular Member Join Date: 16-10-2005 Location: Barnet, North London
My System: Thomson Sky+ PVR3, Pace 2200 Sky box, Zone 1 Triax minidish with Thomson Quad LNB, 1m Gibertini and Technomate TM-1500CI+ Super (Patched) 1metre Gibertini at Astra 1 19.2°e |
Hi, i'm considering upgrading to a 1m dish but am unsure which to go for, i've heard tonnes of fabulous reviews about gibertini dishes and have seen this 90cm one http://cgi.ebay.co.uk/BRANDNEW-90-CM...QQcmdZViewItem but was wondering if it's better than this 100cm golden interstar one http://cgi.ebay.co.uk/NEW-100-CM-HIG...QQcmdZViewItem i'm guessing the Gibertini is probably better but i'd thought i'd ask anyway, specially as the Gibertini is £10 more. | ||
| Regular Member Join Date: 18-11-2004 Location: Belfast, Northern Ireland
My System: Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn. | Televes and Channelmaster also make good 1 meter dishes. Depends on your budget tho... | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | i would say the gibertini dish is better, there is a few members on here with them and they will give you there opinion of them i'm sure they are aluminium so better for diseqc motors | ||
My System: Thomson Sky+ PVR3, Pace 2200 Sky box, Zone 1 Triax minidish with Thomson Quad LNB, 1m Gibertini and Technomate TM-1500CI+ Super (Patched) 1metre Gibertini at Astra 1 19.2°e | okay cheers, so you reckon the gibbi (op85l) is better than the golden interstar 1m, because the gibbi is a tenner more, also r these good prices? | ||
| | #5 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | just noticed 1metre gibertini dish £49 plus shipping from hisat, you could collect it i'm sure if you can get to bristol to save shipping charge _http://www.hisat.com/twp/prod_detail.asp?ID=139 | ||
| | #6 | ||
| Regular Member Join Date: 27-03-2003
| you can get cheaper then that from germany,uk prices tend to be higher,the drawback is the postage costs so its not worth importing them,also if it arrives distorted that could cause a problem. | ||
| | #7 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | well the german price is higher than uk one see on http://www.dvb-shop24.net/index.php/...g8l5r8eu7lk3q5 so best to get from hisat i reckon if martz can go collect it | ||
| | #8 | ||
My System: Thomson Sky+ PVR3, Pace 2200 Sky box, Zone 1 Triax minidish with Thomson Quad LNB, 1m Gibertini and Technomate TM-1500CI+ Super (Patched) 1metre Gibertini at Astra 1 19.2°e | no chance of collecting it, there place is 137.1 miles from where i live, 2 3/4 miles from here, the postage is extortionate £34.72!!!!! | ||
| | #9 | |||
| Member Join Date: 07-04-2006 Location: Luton
My System: Receiver:Mvision & Openbox. Dish: Gibertini 85CM Satellites:28E, 19E, and 13E. Motorised Gibertini 1M |
| | #10 | |||
| | #11 | ||
My System: Thomson Sky+ PVR3, Pace 2200 Sky box, Zone 1 Triax minidish with Thomson Quad LNB, 1m Gibertini and Technomate TM-1500CI+ Super (Patched) 1metre Gibertini at Astra 1 19.2°e | I found this site, with delivery it works out as £61.99 for the OP100L 1m gibertini http://www.satonline.co.uk/shop/products.php?g1=8a20b8 | ||
| | #12 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | seems a good price as the orbital dishes on there are more expensive how come you want a 1m dish going to add a motor at some point ? | ||
| | #13 | ||
My System: Thomson Sky+ PVR3, Pace 2200 Sky box, Zone 1 Triax minidish with Thomson Quad LNB, 1m Gibertini and Technomate TM-1500CI+ Super (Patched) 1metre Gibertini at Astra 1 19.2°e | hopefully, but i really can't afford a motor aswell right now, maybe i'll get a summer job! | ||
