fitting sky quad lnb | |
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish |
are these easy to fit ? also anyone that installs dishes on this forum know what skew setting i should have it at as i have 1-5 on the lnb bracket also once i have fitted it, should i put self Amalgamating Tape around the f connectors as it has a sliding down cover ? and put some self Amalgamating Tape over the spare outputs or will the little plastic caps that came with it be ok ? btw the quad is a zinwell make never heard of these thanks wod | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | They are a doddle wod. ![]() The only thing you may need to do though, is fine tune the dish, as they are heavier than the single and there will be the added strain from the extra cable on the dish arm and more so on the clip in holder. The skew can be played with until you get the best quality reading on the receiver, I use a small amount of self amalgamating tape on the botton of the F connector, but none at the top, as the slide down cover is sufficient protection.
__________________ | |||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | nice one rolfw as they looked not so easy to fit as i've had a look at it and its got some kind of peg that slots into the arm of the dish and also some adapter came with it how do the lnbs come off a sky minidish is there some screws ? as for the skew setting i've seen minidishes with the quad like skewed so its angled to like 7o'clock if you get what i mean | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The old one should slide out after removing the plastic peg, some can be really wedged in. Yes, skew generally is set around that figure.
| | #5 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | i noticed the dish arm had a plastic peg in it, the lnb on the minidish is a channel master or something which gives really good quality signal nearly full on both bars so i hope this quad lnb wont reduce the signal , otherwise it shall be a zone 2 dish off Ebay wish sky would have had the zone 2 dish as standard rolfw a silly question the best way to remove self Amalgamating Tape thats been on a few years , just cut it or anything quick ? you got a installers tip ? thanks | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Stanley knife.
| | #7 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | i'm putting the quad on to add another box otherwise i wouldn't touch the dish just wondering what size drill bit you use to put a cable through the wall ? i know it will be a 10mm but what length masonary bit ? thanks wod prehaps a good idea to put at the top of forum some sort of tool list for self installations | ||
| | #8 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | 10mm x 400mm should do it.
| | #9 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | right rolfw bought a masonary bit 10x400mm today but do you drill from inside out or outside in ? also it best to drill through the brick or through the cement between the bricks if i drill inside out theres a chance of cracking the brick ? i have some of them hole plugs for inside to make it look neat just want the easiest to do and best finish method | ||
| | #10 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You normally drill from inside, as you then know that you are not going to hit anything like cables and won't blow the plaster on the inside wall.
| | #11 | ||
| Regular Member Join Date: 18-11-2004 Location: Belfast, Northern Ireland
My System: Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn. | Best to take your drill of hammer for the last inch or so as you drill out to avoid a big blow out, or you could just buy a blow out cover and stick it on with silicone. Also drill down at a slight angle. | ||
| | #12 | |||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | just know i'm going to burn the drill out as the walls are solid brick not breezeblock and then brick outside | |||
| | #13 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Just take it slowly and do it in several stages if necessary.
| | #14 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | well fitted the quad today and it was easy to do it but that pin in the lnb arm was hard to get out the skew setting ended up on 1 which gave a better signal than the original lnb so it skewed to like 7 o'clock drilling through the wall was so hard burnt my drill out was a crap 700watt hammer drill only got so far luckly i had bought a nice 1500watt sds hammer drill other day from a diy store that ripped through the wall like butter also that wf100 cable i used for the run isn't that flexible around corners think i over did the waterproofing tape abit i put it all over the connectors | ||
| | #15 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Well done wod, the WF100 is designed to be not very flexible, neat right angled corners look good, but are not good for the signal path.
| | #16 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | well i get a very good signal on the mindish its nearly on full for signal strength also i did a lot better job than them cobra installers that originally put the dish up also what is h109f cable ? | ||
| | #17 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Just a cheaper version of airgap coax, I prefer WF100.
| | #18 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | thought so as them cobra bodge it up installers couldn't use decent cable or fit f connectors properly to save there life | ||
| | #19 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | It isn't bad wod, just a bit cheaper.
| | #20 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | rolfw i've attached some pics as to see if the cable run is ok as i had to put some bends in the cable | ||
| | #21 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | That should be OK, WF100 is very difficult to bend too tight.
| | #22 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | great as its been working fine and comparing the signal levels the wf100 cable run gets a better signal excuse the messy cables on the dish as thats how i had to put em as not got any cable ties | ||
| | #23 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | rolfw you got any idea whats wrong as now i cant recieve tp 11.264h on my fta box on the 2nd run from the quad but the channels affected are fine on the sky box so cant be dish alignment and its only this tp so is it the lnb ? | ||
| | #24 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | seems swapping the sky box over to 2nd fta box feed channels affected work fine but connecting the fta box to the sky feed the channels still say no signal ? so is there something wrong with my fta box its a technomate tm1500 ci that i was just using on 28e till i got my motorised dish up | ||
| | #25 | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Have you tried giving it a retune? Usually sorts things out for me...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | ||
