Removing rusty bolts on dish?
Thread Tools Display Modes
Old 22-09-2006   #1
blackninja's Avatar
With a big tree in front of my usual hotbird dish, I've decided to move my skydish over to 13 East. Only problem is with rain etc the bolt on the skydish has become rusty and won't move an inch when I try to unscrew it with a spanner. I've tried tips from a google search such a coke and a flame torch but so far no luck. Any tips?
blackninja is offline   Reply With Quote
Old 22-09-2006   #2
rolfw's Avatar
WD40 and a wire brush may do it.
__________________
Rolf
Donate
Old 22-09-2006   #3
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
If its really stuck try soaking the bolts in WD40 for a couple of days. Then if that fails get a junior hacksaw preferably with a new blade on it.
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Final analogue switch off from all Scottish Borders transmitters - BBC1 ITV C4 & C5 - 0010GMT November 20th 2008.
Old 22-09-2006   #4
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
If you can get a blowtorch on the nut then that will definitely shift the rust. Undo it when the nut is red hot and use a socket set, preferably a single hex (6 sides, not 12) socket. Ring spanners are a second best but don't bother with an open ended spanner - it'll just round the corners of the nut.
If getting the nut red hot might damage other stuff then heat it up as much as possible and then put some heavy-ish oil on, old style 20/50 engine oil is ideal. Don't use WD40 as this will just evaporate without doing any good - the engine oil will thin down nicely and penetrate (ooh Matron) the threads. If necessary repeat the heating/oil procedure a few times.
When you come to undo it DON'T try to unscrew immediately. Give the spanner a slight tightening motion to break the bond between the nut and bolt and then try to unscrew a bit. Keep rocking back and forth gradually working the nut loose.
You'll get it eventually.
__________________
As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after.
PaulR is offline   Reply With Quote
Old 22-09-2006   #5
My System: C and Ku
Rusty Bolt
Suggest you use a grinder and replace with a brand new stainless steel bolt.
wium is offline   Reply With Quote
Old 25-09-2006   #6
My System: Pansat
You Could also use copper or brass as replacement bolts then you will never have rust problem again, WD40 works good.
manning3000 is offline   Reply With Quote
Old 25-09-2006   #7
grahamd180's Avatar
My System: triax 110,Technomate1500ci super,v-box,Jaeger 1224,Dragon Cam,Cas3,Digitalb card,Conax cam,Lots more in shed!
Coat the new bolt threads with copper grease from a car spares shop and you will have no problems in future.
G
grahamd180 is offline   Reply With Quote
[IMG] code is Off
Forum Jump
