How do you crimp Snap & Seal connectors professionally? | |
| Member Join Date: 22-09-2006 Location: England
My System: Telewest Broadband |
I have about 50 Snap & Seal connectors, 100m of satellite cable, and I've even got the compression tool for the connectors. So I've got everything I need. My question is, how do I crimp these connectors properly? How much of the outer sheathing should I take off? How much of the copper braids should I take off? What about the foil shielding? Has anyone got a picture of how to crimp professionally? Thanks. | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | i'm sure theres a guide at the top of the forum to fit f connectors | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Right forum, it's just most of us just use screw-on F connectors, snap and seal are too fiddly (as you say, how much of the core & shielding to expose) and usually used on cable TV systems...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | ||
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Sorry. missed the question, it's about 8/9mm of core and 5/6mm of outer, then fold back the braid and compress the fitting. It doesn't have to be exact and you can always cut off excess core.
__________________ | |||
| | #6 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | derailed where you get the tool and the connectors from as i was after some of them | ||
| | #7 | ||
| Guest
Posts: n/a
| I always use thomas & betts snap and seal connectors best thing is they are water waterproof & very high qulity and are much better then screw on type but beware there are diffrent connectors for diffrent cable, E.G one for rg6. one for rg11 another for ct100 & ct125 and ct150 so you must make sre you get the right type, here is a guide how to fit them go to the last page of the PDF below _http://www.tnb.com/contractor/docs/snapnseal.pdf | ||
| The Following User Says Thank You to For This Useful Post: | RooDBwoY (20-06-2008) |
| | #9 | |||
My System: Telewest Broadband | Thanks guys. If you have any more websites which show how to do this then please post them up. Last edited by derailed; 24-09-2006 at 07:56 PM | |||
| | #10 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | you got a link ? and are the snap & seal totally waterproof ? | ||
| | #11 | ||
My System: Telewest Broadband | It says that you should fold back the copper braids. What about the foil? Should you fold that back too? Cuz I'm sure it'll snap if I tried. Does the connector go between the foil and foam dielectric... or over the foil? | ||
| | #12 | ||
My System: Telewest Broadband | I brought the Snap & Seal connectors several months ago, and I brought the compression tool last week. I'll see if there are some on Ebay | ||
| | #13 | ||
My System: Telewest Broadband | I got my compression tool for only £7 last week. I typed "compression tool" in Ebay And I can't see the Snap & Seal connectors at all. hm... | ||
| | #14 | |||
| Guest
Posts: n/a
| All high qulity snap & seal's are water proof but i always put a bit of tape on them any way, They ain't that hard to fit i had to make up a few 2 meter leads the other night for a job and my 5 year old did most of the connectors on there if she can do it you will not have any problems, best place to buy them is Ebay here is a tools same ones as i have don't bother with the cheap ones as they dont last long 9709751327 120031981280
| | #16 | |||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide |
__________________ Oldgeezer | |||
| | #17 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | when fitting the connector does the center part of the connector slip under the copper foil on wf100 cable as how do they fit before compressing ? as you dont want to get the foil or braid stuck in the connector when compressing it or do you cut it off ? any one got some pics of a stripped cable before hand ? | ||
| | #18 | |||
| Guest
Posts: n/a
| Here is some pics for you, As you can see cut the coax push the f-con on so the smaller cener bit of the f-con goes over the center foil be careful no to snag the ali/copper foil and then seal the f-con job done,
| | #20 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | With WF100 you will need to peel off the copper foil, it is too thick to go inside the connector and gives you real problems when trying to push the connector home, RG6 as Rd100 shows, will work without removing the foil.
| | #21 | ||
| Guest
Posts: n/a
| Yes it is a pain with wf100 but you can peel the foil off if you have problems with the wrong size f-cons but this is due to rg6 f-cons thomas & betts do UK grade f-cons for wf100 & wf125 which are different sizes to the USA & standard rg6 ones also do a | ||
| | #22 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | yeah but i'm stuck with this as you strip the cable but how far do you push it on as its pushing the braid and foil down under neath the outer sleeve of the cable when i try to push the cable up to the top of the connector wish i hadn't bothered as looks more trouble than its worth | ||
| | #23 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | No it isn't wod, I'll take a couple of pictures now.
| | #24 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | this is doing my head in as what size do i strip the cable to as i have the same stripper as in those pics because the connector wont push up to the end is that enough in the pic below do i need to cut the outer sheath so the connector will allow the foam dielectric to push right up to the end of the connector as when i push the connector on it just pushes the foil and braid further into the cable rd100 you mention t&b do wf100 snap n seal where can i get some of those ? | ||
| | #25 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Click on individual thumbnails to enlarge them Strip the cable, about 1/4" on both sections cable1.jpg Fold back the braid cable2.jpg If you try the connector now with the foil, it will bundle up the foil as in the picture above, so strip it off cable3.jpgcable4.jpg Push on the connector with the braid still pulled back over the outer, a warm cable makes it easier cable5.jpg Then crimp. cable6.jpgcable7.jpg
