no hotbird on twin lnb
Thread Tools Display Modes
Old 23-09-2006   #1
My System: skystar 2 pci card(driver 4.4) using progdvb(latest) and s2emu(v1.26) most likely to use astra 19.2E, but if possible i'll switch to astra 28 for skyuk
hello.
i set up my dish(80 cm) with a twin lnb pointed at 13E for hotbird for the central lnb, the second one should receive astra 19.2. in the store they gave me a 2 in 1 diseqc switch and told me to put the hotbird lnb to position A and the astra to B. i have never managed to get hotbird signal. astra works fine. when i tried to switch A and B nothing worked.
i used to watch with a no-name receiver, but i am now switching to a skystar2 pci card, with the same results. what have i done wrong?
thanks for the help.
ipuggle is offline   Reply With Quote
Old 23-09-2006   #2
rolfw's Avatar
Well in real terms a twin LNB only points at one satellite, but has to identical outlets for two receivers.
If it is a monoblock with a single output, then it doesn't require a separate switch.
Can you take a couple of photos and post them as an attachment?
__________________
Rolf
Donate
[IMG] code is Off
Forum Jump
