zone 2 minidishes | |
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish |
how much more bigger than zone 1 dishes are they as from looking at them , they are so much bigger visually. is the size difference much that they are worth replacing a zone 1 for as reason for asking is at weekend put a quad on my sky dish and some heavy rain today and the signal went all over the place it was fine before with single lnb and the cables aint tied to the lnb arm to pull it down also how come i've only seen zone 2 dishes on pubs and not many homes are they more expensive to buy for installers ? thanks wod | ||
| | #2 | |||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! |
Weeeeeell, Zone 1 are 43cm, and Zone2 are 60, so that's ~20cm difference (look at a ruler or tape measure to see the diference... ), and personally, I'd just put the Zone1 in the cupboard as a backup (incase you lose the bigger dish in a windstorm or a chav shimmies up your drainpipe and pulls it off) and get a Z2 for the bigger bad weather margin.As for why they're on pubs, one in Nelson near where I work (the Lord Nelson, there's a shop mentioned next to it on analoguesat's website with a BSB squarial on the back, I took the pic ) has 3 and one Z1, and the three Z2's look like they're pointing at astra 1 and/or Hotbird.Also, sky are cheapskates so they use what dishes they can get the cheapest which can just about do the job for the area they're used in, if they could, they'd probably supply bin lids if they were cheap enough!!!
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | well there cheap on Ebay also are the mounting holes on the zone 2 same as the zone 1 brackets so i dont have to redo them ? what i would do is swap it completely for a 60cm 40mm collar dish with quad but they aint allowed with a 1metre aswell are they ? anyone got the exact sizes as i read that they have wierd sizes like the dish is wider than the horiztonal size | ||
| | #4 | |||
If the Z1 is the old style with the bent tube then yes, if it's the raven-type flat bar thing, then no... As far as I know, you can have a main dish upto 1M in size and a second dish upto 60cm, so you'd be fine with a 60cm proper 40mm collar dish... Asdigi says he has a few Z2's so you can pm him to get the ol' tape measure out and measure them, and yes, minidishes are wider than they are taller, whereas normal dishes are taller than they are wider (but you measure the width, not the height)...
| | #6 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | i have another question what size pole can you mount a sky zone 2 dish to ? will they fit a 2" pole ? as i'm wanting to put up a motorised dish on t&k brackets and the minidish gets in the way so thought of putting them both on the same pole | ||
| | #7 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I think that they take a 1.25" inch pole with standard U bolts, but I managed to cobble mine onto a Moteck some time ago. If you can afford a little more, get a Raven Gemini 70cm, much nicer dish.
__________________ | |||
| | #8 | ||
| Knowledge is power. Join Date: 30-09-2004 Location: Leeds
My System: Amstrad Digibox and zone 2 dish. Technomate 1500ci+, 90cm motorised dish on a very thick pole! | Ive had a 60cm up for a few years and it does give a significantly better signal than the 45 but I still couldnt get everything. Make sure its on a strong pole as mine is prone to badly losing signal in windy weather as the 60cm is great when the weathers nice, but still not much cop when its blowing a gale and wobbling about! | ||
| | #9 | ||
My System: Amstrad Digibox and zone 2 dish. Technomate 1500ci+, 90cm motorised dish on a very thick pole! | Sorry, meant to say it is a 1.25 pole mine is on, held with U-bolts, hence the 'wobbly in wind' problem. | ||
| | #10 | |||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | beginning to be a pain in the arse this bloody minidish. can't move it as the cable runs wont be long enough | |||
| | #11 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I used two 3" thin U bolts crossed over to fasten mine, they came from a masthead amplifier. If you struggle, I may have a couple of spare ones.
