Dish in the attic
Thread Tools Display Modes
Old 26-09-2006   #1
Freelance Sniper
itisix's Avatar
My System: 1,25m Fixed offset; Quad LNB's; 2 x Edision 2100; 13ºE; 19.2ºE; 28.2/28.5ºE
Dish in the attic
I have a house with a big attic and it's not beeing used. I was wondering if it would be possible to place a 1.2m dish inside it. the roof is mildly inclined facing almost perfecly 30ºW.
the height of the attic is 1.5m.
I'd like to capture 13ºE, 19.2E and 28E in portugal with the same dish and 3 LNB's (no motor).
28ºE requires quite some sized dish (at the very least 85cm according to reports; a guy I know has one on the roof and get reasonable quality, but I'm going 1.2m) in Portugal because of low signal.
There are no windows in the attic but I would (off course) place one or more onto the roof and replace the glass with acrylic or other material.
Would this be at all possible or am I just daydreaming?
__________________
Jayne: Do you know what the chain of command is? It's the chain I go get and beat you with till you understand who's in rutting command here.
itisix is offline   Reply With Quote
Old 26-09-2006   #2
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
If the roof is sloping facing 30W you are going to have problems getting the easterly satellites!
However. As long as the material you use is microwave transparent then yes it will work to some degree. You will have some signal loss due to absorption and probably due to refection off the surface of the new window. You may well find one polarity more affected than the other.. You will also find more signal degradation in wet weather if rain sticks to the acrylic outer surface...
To be honest its all guess work, but try it and see!
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Final analogue switch off from all Scottish Borders transmitters - BBC1 ITV C4 & C5 - 0010GMT November 20th 2008.
Old 27-09-2006   #3
My System: DM7020 Screambox MAC OSX & windowzz 98SE Gemini 1664 on tap
and if it does work itisix please come back here and report your progress - this is agreat idea !
whatsthis is offline   Reply With Quote
Old 27-09-2006   #4
spiney's Avatar
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
Yes! (provisionally).
It's certainly possible to use a sat dish - of any size - through most standard window glass (ie, that made by the Pilkington float process, so it's flat, that is, the scenery outside doesn't seem to "ripple" as you move!).
However, some types of glass can selectively attenuate parts of the Ku band, especially high band - depending on chemical composition - so the only sure test is to try it!
I have no problems at all getting Astra1/Astra2/Hotbird, through my double glazed kitchen window, on a Sky Minidish (Hotbird is partial, but that's the small dish size, not the glass!).
spiney is offline   Reply With Quote
Old 27-09-2006   #5
Freelance Sniper
itisix's Avatar
I'm from portugal and it's rather delicate to get astra 2 here because of low signal. astra 1 and hotbird are really hot around here, but astra2 requires (at the very least) a 1m dish so I'm shooting for bigger. the problem as I see it is the slop of the roof as it is almost 90º to the antena. I'd really like to put it up there. It would last longer (no corrosion from the neraby sea at less than 1km), no rain to short the LNB, no birds messing with the "arm", easy access (and always dry )
the problem is that to make it effective, the window must be big. at least as big as the dish (or bigger because of the roof slope) to have signal reaching all the surface of the dish. I don't know. maybe won't even try. on the other hand, all the wiring will go in the attic.
__________________
[IMG] code is Off
Forum Jump
