Indoor reception?
Thread Tools Display Modes
Old 28-09-2006   #1
My System: Star Sat SR-X 150 D Plus MAC OS X 10.3.7
Indoor reception?
Is there any technology available for satellite programme reception without the use of an outdoor dish and LNB, etc.?
Any kind of antenna or other receiving apparatus that can instead be placed indoors or at least 'behind a window' on the inside?
If so, what is the name of such a setup, its capabilities, limitations...?
I'd be grateful for any advice on this.
nahavandi is offline   Reply With Quote
Old 28-09-2006   #2
rolfw's Avatar
There are several threads discussing inside dishes, they do however need to be pointing out through a window and the window needs to face in the approximate direction of the satellite.
__________________
Rolf
Donate
Old 28-09-2006   #3
Freelance Sniper
itisix's Avatar
My System: 1,25m Fixed offset; Quad LNB's; 2 x Edision 2100; 13ºE; 19.2ºE; 28.2/28.5ºE
limitations come in the form of the direction of the window.
_http://www.selkirkshire.demon.co.uk/analoguesat/paintingdishes.html
_http://www.allegiantinc.com/
_http://www.selkirkshire.demon.co.uk/analoguesat/windowdish2.html
check these websites.
also, you may need to replace the glass and avoid using double glaze.
There are some alternate antennas. One is a flat antenna and the other is kind of a pipe (equivalent to a 55cm, but not sure).
just google it around and try to find a sollution. be aware of the size you may need and that even with plastic or plain glass you should expect some signal loss on certain frequencies.
cheers,
__________________
Jayne: Do you know what the chain of command is? It's the chain I go get and beat you with till you understand who's in rutting command here.
itisix is offline   Reply With Quote
Old 28-09-2006   #4
Thank you for the prompt attention.
I will search and review the various options; meanwhile, if anyone has
experienced the so-called alternate antennas such as 'flat' or 'pipe', etc., I'd be pleased to hear from them.
Old 28-09-2006   #5
Freelance Sniper
itisix's Avatar
can't help with that, but take a look at _http://www.satlex.de/en/gallery.html.
I think I saw some indoor antennas there once in one of the galleries.
I myself was trying to find a way to put my dish in the attic but it's not sloped the right way.
good luck with your roaming.
cheers
__________________
Old 28-09-2006   #6
rolfw's Avatar
No need to send people elsewhere, have a look in our pictures of members' setups, there are several in there.
My tiny Hispa dish (through window!)
The only bed in the world with a dish
__________________
Rolf
Donate
Old 28-09-2006   #7
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased...
The Sleepy Hollow pollracle has spoken!
I have an Attisat FL500 Flat Plate Antenna (FPA) and as performance on Hispasat indoors goes, it was as good as my 60CM dish, however, I've upgraded the LNB but haven't had a chance to test it yet. As for the pipe antennas (or as I like to call them, Satellite Sausages), I've not tried one before...
__________________
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
Resident KIRBY Vacuum nut...
2cvbloke is online now   Reply With Quote
Old 29-09-2006   #8
2cvbloke,
Thank you for the information.
Where did you get the Attisat FL500 and how much?
Do you know of any specialist stores or outlets in London for such flat antennas?
All the best.
Old 29-09-2006   #9
Freelance Sniper
itisix's Avatar
2cvbloke,
All the best.
I've seen one for £125. perhaps you could place one right outside as they are quit slim.
__________________
Old 30-09-2006   #10
2cvbloke's Avatar
2cvbloke,
All the best.
I bought mine off Ebay for just over £20, there's one on right now but it's at £31 at the moment, just do a search on Ebay for this number:
230032995036
As I said, mine was about the same as a 60cm dish, so you may want to make sure that it can receive the satelites theat you're after...
As for shops, I don't know, however there is this website who have a Flat Plate antenna equivalent to 50cm for £109 (remove the _ when copying and pasting the address):
_http://www.sateuropa.co.uk/product_overview.asp?id=829&catid=1&subcat=2
__________________
« confused | c band »
[IMG] code is Off
Forum Jump
