1 dish with multiple LNB's? | |
| Regular Member Join Date: 18-10-2005 Location: London
My System: Wave Frontier T90 Dreambox 7020S-Gemini 4.10 8 lnb's |
I've been told that its possible to have 1 dish with 6+ LNB's on. Am in the UK so the signal strenght isn't an issue. Can you direct me to the right places for this setup? Thanks | ||
| Folding*home Join Date: 23-02-2006 Location: Madeira
My System: [ Relook 250S ] | Something like this? _http://www.satlex.de/en/wavefrontier-page_1.html
__________________ ![]() When people ask me what I think, I tell them: "I think all of the meat around the pig's ass is pork." | ||
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Which satellites are you intending to pull in?
__________________ | |||
My System: Wave Frontier T90 Dreambox 7020S-Gemini 4.10 8 lnb's | Basically I want: 5,13,19.2,28.2,39. I could ignore 39 if that would save me from a lot of trouble. My dish is triax 110. big enough? | ||
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | A Raven Gemini 90cm with both East and West offset brackets would do those satellites easily, if you were prepared to forget about 39E.
| | #6 | ||
| Freelance Sniper Join Date: 31-08-2006 Location: Portugal
My System: 1,25m Fixed offset; Quad LNB's; 2 x Edision 2100; 13ºE; 19.2ºE; 28.2/28.5ºE | yup. much easier to have only 4 satellites. you can use a diseqc switch with 4 of them.
__________________ Jayne: Do you know what the chain of command is? It's the chain I go get and beat you with till you understand who's in rutting command here. | ||
| | #7 | ||
My System: Wave Frontier T90 Dreambox 7020S-Gemini 4.10 8 lnb's | I've found a triax multifeed which takes 4 lnbs but i can only do 20 degrees when I need 23 5-28. Is there any universal that would do the job? A friend of mine in east UK has full signal on viasat(sirius) with 80cm dish. Is my dish big enough for sirius? Am in london | ||
| | #8 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | You have to remember that dishes work best with the lnb very close to the main axis of the lnb arm. Off axis lnb's decrease the signal strength rapidly. Theres no point you trying for something like 5E and expecting all the weaker tp's to appear at full strength if the lnb is 15-20 degrees off axis..... If you want a huge range of sat signals on one dish then invest in a dish designed for the job - like that Wave Frontier mentioned up the thread.
| | #9 | ||
My System: 1,25m Fixed offset; Quad LNB's; 2 x Edision 2100; 13ºE; 19.2ºE; 28.2/28.5ºE | I'd say go for the wavefrontier toroidal. I was going to get one, but I need something bigger. I talked to the guy from satlex who had one, and he told me the antenna was great at pulling many satellites with very good quality. he only traded it because of the size (90cm). there is another one called Vantage MB85 that can handle up to 40º (may not be as good as the wavefrontier, but don't really know about it). It is cheaper, as the wave frontier can cost from €150 to €250. cheers
| | #10 | ||
| Regular Member Join Date: 03-04-2004
| I live in Surrey and have a 90cm Toroidal with 8 LNBs ranging from 5w to 28.2e and I get a very good signal from all the transponders. I centre on 13 allowing me to find the outside satellites. The dish is an absolute bu**er to set up, it took me about 3 weekends to get the signals to a level where I could get the channels, and a few more tinkering with the settings to fine tune, but the results are good. The support at Toroidal are also good and helped with a few questions that I sent over email. Good luck! HTC | ||
| | #11 | ||
My System: 1,25m Fixed offset; Quad LNB's; 2 x Edision 2100; 13ºE; 19.2ºE; 28.2/28.5ºE | you can take many satellites in with the wavefrontier. I pulled this out of satlex. it has 14!!! lnb's and 18!!! satellite positions. as I said before, the guy who owned it said it is a really good antenna if you don't need bigger. I really wanted to buy one of these but not big enough (dish surface). does anyone know of a bigger (at least 1.1m) toroidal antenna?
| | #12 | ||
My System: Wave Frontier T90 Dreambox 7020S-Gemini 4.10 8 lnb's | I cant really afford buying a new dish. I thought of puttin 2 lnbs and keep my diseq 1.2 motor in place. Would that be trouble free? I got many people watching from 1 sat dish so i cant really play with the satellites, at least i would prefer 13 and 19.2 from one position. | ||
| | #14 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Not as far as I know.
| | #15 | ||
My System: 1,25m Fixed offset; Quad LNB's; 2 x Edision 2100; 13ºE; 19.2ºE; 28.2/28.5ºE | looking for one myself.
