inverto lnb prime or offset focus | |
| Specialist Contributor Join Date: 11-12-2004 Location: yorkshire
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro |
hi could anyone check the following link and tell me if its suitable for a 1.2m channel master offset dish, the guy who sells them says its for a prime focus dish and i need one with a 40mm collar, but i thought a feedhorn could be used with this, and a 20 to 40mm collar,thanks for any info just not sure if lnb different for prime focus and offset ![]() its Ebay | ||
| ASBO Club Member - Persona non grata Join Date: 30-07-2003 Location: Stockholm, Sweden
| Yes that is the one, but you need a Andrew feedhorn also to it. Seems Wizard sells the Andrew dishes so just contact them and they could probaly order the Andrew feedhorn for you. http://www.wizardsatellite.co.uk/ind...roducts_id=265 Just tell you want the Andrew feed with part number Andrew Rx Feedhorn p/n 611606007 | ||
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | thanks for the reply again likvid, ill try again but it seems no one wants to sell me one | ||
| | #4 | |||
| Guest
Posts: n/a
| Well they guy who told you that knows shit all about satellite, You just need the lnb and feedhorn prime focus or offset
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Don't buy the LNB on Ebay I wonder how many customers back out during the checkout though, when they see that they require your date of birth, really can't see why they need it, as the registered address of the credit card should be sufficient.
__________________ | |||
