Have I put this together correctly??
Thread Tools Display Modes
Old 02-10-2006   #1
Ey up, Sither!
femto's Avatar
My System: Echostar AD3000-IP, Manhattan Plaza ST100, Gibertini 1m Dish, Inverto Silver Tech 0.2, Polar Mount, 12 Inch Actuator, Dragon CAM
It's a Gibertini Polar Mount with a Superjack 12 inch actuator.
Anybody see anything wrong with what I've done?
Thanks people!
femto is offline   Reply With Quote
Old 03-10-2006   #2
Ey up, Sither!
femto's Avatar
Bump..?
Surely someone here has fitted a jack to a Gibertini polar mount??
It appears to drive the mount okay - I was just wondering if anyone with experience in the assembly of such a thing thinks it's done correctly.
The mount has already been set so that it tracks the arc as I set it up, without the motor attached, on a ground pole which I know is dead plumb. I thought I'd be best to set the angles up before I'm at the top of a ladder!
I got good signals from Turksat 1C at 42E, 28.2E nearly bent the needle off the meter, as did 19.2E and 13E. 10E was an easy catch, as were 7E 5E 1W 5W 8W and 30W. I think that 43W was obsured by the house over the street from the ground pole as I only saw a slight lift on the meter as I passed what I thought was 43W but even if I can't see that bird, I'll not be too disappointed.
I think I've got the angles on the mount and the dish right as I'm seeing 42E, all the middle satellites and right through to 30W.
I don't think I tried to find 36E or 23.5E but if I don't get anything from them once the dish is on the pole upside the house, I'll look into that later.
Any comments on whether I've fitted the jack in the right way will be useful, thanks.
Old 03-10-2006   #3
CROSSBONES's Avatar
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card.
Here you go m8 this should act as a guide
CROSSBONES is offline   Reply With Quote
Old 04-10-2006   #4
Ey up, Sither!
femto's Avatar
Excellent stuff, Crossbones! Thanks very much.
The only difference that I can see is that I have put the jack on the opposite side and in the picture the extending part of the jack is underneath the arm on the polar mount rather than on top, where I put it. I'll try moving the jack to underneath and see if it makes much of a difference.
Although.... I dont suppose it matters too much so long as the jack is bolted on in such manner as to make sure it's straight, i.e. not attached to the bracket at a funny angle.
Just waiting for my ladder to come back and I'll be putting this lot up.
I'll post some pictures when I'm done and I'll give a report on what I can receive.
Thanks again.
Old 04-10-2006   #5
CROSSBONES's Avatar
Yes m8 bolt the end of the jack under, like on the pic.
Also put the mount on 1*w and mount the actuator half way like in the pic.
Get some pics up m8 when its installed
Good luck
Old 04-10-2006   #6
Ey up, Sither!
femto's Avatar
Well, I looked at that picture and thought that it had been put together a bit strangely in that respect... If the jack is clamped in that position, the jack arm is fully retracted when the dish is pointing at Thor. Surely this would mean that there is no travel available to go any further west - only east. The only direction that the jack can move in from its current position is outwards, which will drive the dish round to the east....or am I missing something.
Do you not have to set the actuator to half way through its travel before clamping it down at 1W?
Old 04-10-2006   #7
rolfw's Avatar
Can you not drive the jack out to half way and then slide the mounting bracket along?
__________________
Rolf
Donate
Old 04-10-2006   #8
Ey up, Sither!
femto's Avatar
Well what I did was I put the mount as far to the east as it would go and then went back a small amount and then bolted the jack to the mount.
I then connected to the receiver and set the east and west limits. There's still enough travel to go right past 30W and I think the eastern limit is something like 55E. I know the polar mount and dish backplate are set at the correct angles so as the motor drives the mount fine, I'm assuming that the setup is okay.
I will however reposition the end of the jack so it is underneath the arm on the polar mount as in Crossbones' attachment.
P.S. My ladder arrived this morning so I will be able to put the pole up either this afternoon or tomorrow morning. I'm looking forward to the end result (so long as it's a good result!!)
Old 04-10-2006   #9
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Looks like you have a good setup in the making there.
Should give you years of use, mine's been running smoothly for fifteen years in all weathers: just smear the piston with a little silicone grease occasionally, and make sure the locknut at the dish end doesn't work loose (can happen).
__________________
Llew is online now   Reply With Quote
Old 04-10-2006   #10
Ey up, Sither!
femto's Avatar
Thanks for the encouragement, Llew.
I've put some pictures in the "Picture Forum of Member's Setups" with some more details fo this installation. Just got to make sure my mounting brackets are sufficient. No doubt some of the installers on the site will have some thoughts.
[IMG] code is Off
Forum Jump
