Echostar 3600ipv Settings | |
| Knowledge is power. Join Date: 30-09-2004 Location: Leeds
My System: Amstrad Digibox and zone 2 dish. Technomate 1500ci+, 90cm motorised dish on a very thick pole! |
Hi, me again! My dad has recently moved house and has taken all of his motorised kit with him, the receiver being an Echostar 3600ip Viaccess. I have got him a good price for a motorised installation but the installers want to know if the Echostar is DisEsq compatible as they wont do it otherwise. They said for him to set the receiver up and look on the menu to see if it is DisEsq or ARM(?). Which menu should he be looking at and how does he get to the menu to find this info? He has it switched on now but can only see something called 'autosat' which I presume isnt what he is looking for? Many thanks in advance chaps. Regards Phil P.S. I will, of course, take full credit for the answer when I speak to him and pretend I knew all along and didn't have to ask anybody | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | The AD3600 only has Diseqc 1.0, which means you can only use an actuator ('ARM') or 36V motor to drive the dish. No provision for using a motor that uses other Diseqc commands to move the dish. You can download a manual from _www.echostar-int.com. Llew Last edited by Llew; 04-10-2006 at 03:30 PM | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | If it was set up at the old address, then you could probably do it at the new. If the dish settings have not been altered, and he hasnt moved that far away, lat and long etc. Even if the installer`s do it, then why are they asking if its diseq. The actuator I assume is still with your fathers dish? | ||
| | #5 | ||
My System: Amstrad Digibox and zone 2 dish. Technomate 1500ci+, 90cm motorised dish on a very thick pole! | I really am not sure to be honest, he says it still has everything. He has moved about 25 miles away. The installers said they wouldnt do an ARM install and only DisEsq, which is fair enough as at least they are upfront about what they will do. | ||
