hellas 2 lnb settingsInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Regular Member Join Date: 21-12-2005 Location: Europe, Ukraine
My System: pentium 4 3.06ghz with ht, 1 gb ram, ss2, 1.15m motor dish, strong srtv50 |
Trying to find hellas2 39E on my motorized dish, however much as I move it between 40E and 36E I just can't get any signal. I've used the default progdvb lnb settings: Ku band LOF1: 9750 Switch: 11700 LOF2:10600 does this have anything to do with these settings? I don't know why I"m not geting it if not, after all I'm in the capital of ukraine and hellas2 is only with greek and ukrainian content. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Make sure that you are looking for a strong transponder 12524 V 30000-5/6 is a good one. Sorry scrub the above, just looked at where you are and nothing is very strong for your location. Have a look at http://www.lyngsat.com/hellas2.html and click on the satellite beams, you will see where the coverage is. Always try and seek the higher symbol rate transponders when searching. | ||
My System: pentium 4 3.06ghz with ht, 1 gb ram, ss2, 1.15m motor dish, strong srtv50 | Yess! thanks! found it using your transponder info. so, the higher the value, like in lamens terms for instance 12683 V is better than 10955 V simply because the value is higher? Again thanks, great site! | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | No, the symbol rate. | ||
| | #5 | ||
My System: pentium 4 3.06ghz with ht, 1 gb ram, ss2, 1.15m motor dish, strong srtv50 | uhuh, thanks. also thanks for taking the time to create the shadow under the arrow, very thoughtful | ||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | LOL, keep meaning to untick the shadow box. | ||
| hellas, lnb, settings |
