Dish Upgrade | |
| Regular Member Join Date: 20-08-2006 Location: South East England
My System: Technomate 1500 ci 90cm Gibertini Inverto Silver Tech 0.3lnb Moteck 2100A motor |
I recently set up my present system with an old 70cm Uniden dish, with the help of the forum. Thank you. Well my system performance is quite good. But I am wondering whether to upgrade my dish. My dilemma is should I go for an 80cm or a 90cm. The reason for my dilemma is that I live about a mile or so from the sea and it gets pretty windy here. The Gibertini 90cm looks lighter and has a slightly smaller profile than the Triax or to go for the outsider a Hirschman 90cm. The other option is to play safe with an 80cm. Any comments please. Also roughly how much extra will I be able to pick up. Thanks Clive | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The Hirschmann FeSAT is a beautiful dish, very strong and with an aluminium face and stainless steel bracket, should survive your coastal location, but may be a big ask for the Moteck in a very windy environment. The other option is a Channel master/Andrews dish, much more robust, but probably too heavy for the Moteck.
__________________ | |||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | or one of them transparent dishes made of plastic or something andrews with polar mount actuator would be best | ||
| Ey up, Sither! Join Date: 28-11-2005 Location: W Yorks, Lat: 53.87 Lon: -1.93
My System: Echostar AD3000-IP, Manhattan Plaza ST100, Gibertini 1m Dish, Inverto Silver Tech 0.2, Polar Mount, 12 Inch Actuator, Dragon CAM | Yes, a polar mount would be far far more robust than a Horizon to Horizon mount if you're dealing with strong coastal winds on a reasonable sized (90cm) dish. The only negative aspect to consider with regard to a polar mount is that you will not get as far east and west as you would with a Moteck or similar. If you're okay with 45 degrees east through to 45 degrees west (sometimes slightly more depending on the design of the mount), a polar mount would be the favourite in my opinion. In order to drive a polar mount and jack actuator you will need either a receiver that has a built-in 36 Volt positioner or a V-Box, which enables heavy duty (non Diseqc) motors to be used that move your dish without the dangers of breakage or slippage in high winds. A plus point to the polar mount and 36 Volt jack is that should your motor (jack) fail, not that it will if properly weather-proofed, you don't have to disturb the mount, that is, you can replace the jack for a new one and you will not have to reset your dish to get it tracking the arc again. If a H-H motor dies, it's all to do from scratch! Please accept my apologies if I seemed to waffle on! | ||
| | #5 | ||
My System: Technomate 1500 ci 90cm Gibertini Inverto Silver Tech 0.3lnb Moteck 2100A motor | Thanks It sounds like an 80cm for now and if an upgrade is needed a polar mount is the way to go. I dont really want to change my motor as its only 4 weeks old. Maybe then the Hirschman 80cm as it is a third less weight than the 90cm or a steel Gibertini. Clive | ||
| | #6 | ||
My System: Echostar AD3000-IP, Manhattan Plaza ST100, Gibertini 1m Dish, Inverto Silver Tech 0.2, Polar Mount, 12 Inch Actuator, Dragon CAM | Ah well if you've only just bought your H-H motor, it'd be a shame to waste it now you've got it. Just don't skimp on your choice of dish. You've got a good LNB already - I've got the same model and it's great. You won't go far wrong with a Hirschman or Gibertini dish - I've been reading a lot of praise on this site by some very clued-up members. You can read as many company sales pitches as you like but when professional installers and veteran enthusiasts like them, you must be onto a winner there! Plus, to squeeze as much performance out of your system as you can, make up a patch cable to go between your LNB and your DiSEqC motor (and your motor to your receiver) using the best quality co-ax you can. None of this TV downlead rubbish. It may only be a short piece of cable but every little helps surely.. | ||
| | #7 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | you might as well go for a gibertini 90cm dish | ||
| | #8 | ||
My System: Technomate 1500 ci 90cm Gibertini Inverto Silver Tech 0.3lnb Moteck 2100A motor | The 90cm Gibertini was sort of where I had started. Regarding the cable between the lnb and motor I have used CT125 is that good enough?. Clive | ||
| | #9 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | yes that is good cable and have you used that then from the motor to your receiver ? | ||
