Help! All signal gone
Thread Tools Display Modes
Old 06-10-2006   #1
My System: Not set
I have a motorised system, with 1m disc and Technomate 1500 CI+ receiver. About 2 days ago when I was watching a Digital+ chanel, all of a sudden the receiver reported bad or no signal. Then I changed to another satellite, it seems all the satellites have the same problem. I used motorise setting, to move the disc, but no signal found. I checked the motor and the disc, there is no sign of any loose, shift or damage. The weather of that day was abosulutely fine, no wind or rain.
Today I tried to adjust the angle of the dish hoping to get the signal back, but not sucesseful. No matter whatever angle I moved the satellite, the signal quality never get over 7%. The level is constantly 68-70% (by the way, what does the level indicator mean? I refer to the two bars on the screen when you use motorise setting on TM1500. The upper bar is Level and the lower one is Quality). I don't know what is wrong now. Could it possibly be the problem of LNB? What should I do?
winstonli is offline   Reply With Quote
Old 06-10-2006   #2
Amo Amas Amant Admin
Topper's Avatar
Well
It could be very many things but I would suspect either the ingress of water into the cable from the lnb to the stb, the lnb has failed or the receiver has developed a fault. The only way to eliminate the possibilities requires getting hold of other equipment and replacing logically and systematically to isolate the problem.
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 06-10-2006   #3
Donate to this board
Park Royal's Avatar
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
Living close to London Transport electric railway lines, my motor has lost direction a few times due to arcing from the railway. I just send the dish to zero/Go to Ref, this solves the problem for me. It might help you to try that winstonli.
PR
Park Royal is offline   Reply With Quote
Old 06-10-2006   #4
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Intersting, that's one hazard I wouldn't have expected
__________________
Llew is offline   Reply With Quote
Old 07-10-2006   #5
Park Royal's Avatar
Hello Mr Llew
If your post was in regards to my post. I am close to the junction where the Central line crosses the Piccadilly line, lots of arcs and sparks, more so during wet weather.
When I bought this property earlier this year, the seller was going into sheltered property, the old boy left his satellite gear set up (hence my equipment is second user). He told me what to do if the motor did not pick up the satellites and his advice seems to work. Perhaps it is airborn interference affecting the motor, or perhaps it is a mains born problem. Might think about running the receiver through a suppressor sometime in the future to see if that helps.
Anyhow, I thought that if the O/P tried sending his dish/motor to reference it might solve his problem.
PR
[IMG] code is Off
Forum Jump
