New Channels
Thread Tools Display Modes
Old 06-10-2006   #1
My System: GBSAT 2CI, 80cm Comag eliptical dish, Moteck SG2100A MOTOR
New Channels
Hi Guys,
Each day i check on King of Sat for any new FTA channels.
I am picking up good signals from 30W to 42E.
I put in the transponder frequencies and start to scan, but the scan finsishes without registering the new channels.
I have just changed LNB to a 0.2db thinking this would help, signal strenth and quality has increased slightly.
I have an 80cm eliptical on a Moteck SG2100A and am sure everything is plumb as i get channels on all these satellites.
Basically i guess i am never going to get all channels going.
Would a bigger dish be an advantage?
Any ideas appreciated.
Thor25rtn is offline   Reply With Quote
Old 06-10-2006   #2
Ey up, Sither!
femto's Avatar
My System: Echostar AD3000-IP, Manhattan Plaza ST100, Gibertini 1m Dish, Inverto Silver Tech 0.2, Polar Mount, 12 Inch Actuator, Dragon CAM
Well, what sort of Signal strength/Quality are you getting on various satellites? I know I can't really compare your readings to mine as it's all relative but it might give me an idea.
Also it depends which specific beams these new channels are on, on each satellite. If the new channels are on a beam that points at a different part of the world to Nottingham, you may not get anything....say if a new channel pops up on a transponder which transmits on the Eastern Beam of Turksat 42E, you won't receive it. Not without one heck of a dish!
Anyway, what sort of strengths are you getting?
femto is offline   Reply With Quote
Old 07-10-2006   #3
Smile Signal Strength
Hi Femto!
Signals on say 16E are 80%strength and 65% quality.
26E 70% strength and 49% quality.
I have no strengths below 70% and qualitys below 43%.
As i say even weak qualitys for some stations on 5E gives a good picture.
I take on board what you are saying, so i cannot expect to get every channel, mind you once i have my Dragon CAM soon, i'll have more than enough to watch!!
Many thanks for your reply.
Old 07-10-2006   #4
My System: technomate 1500 strong 4375 pace digi box triax 1.1, triax 88cm
too many channels?
you probably will be on the sats ok, it might be you already have too many channels in the box, that happened to me using a fortec star, i got rid of some and then i got some of the channels in that i wanted
johnwilliam1 is offline   Reply With Quote
Old 07-10-2006   #5
Smile
Thanks for that, will try to remove some channels to see how it goes.
Old 07-10-2006   #6
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro
looks like your channel list might be full or your exiting the search before the receiver has saved them in memory good luck
iwol is offline   Reply With Quote
Old 08-10-2006   #7
Smile Sorted!
Hi Guys,
Many thanks, scrubbed some cahneels and re-tried, no problem.
Still have more to get rid of!
Thanks to this forum the obvious isnt always so obvious.
Cheers!!
[IMG] code is Off
Forum Jump
