andrews feed horn big dissapointmentInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #26 | ||
| Specialist Contributor Join Date: 11-12-2004 Location: yorkshire
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | thanks guys yes it is a 1.2m cm what difference does the wave guide make and should it come with the feedhorn | ||
| | #27 | ||
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | the difference just measured is about 4 to 5 percent roughly the lower figure with the feedhorn just tried again with maximum and some channels on 7w are watchable but with the inverto/feedhorn none watchable infact not clearing at all it seems the 4 or 5 percent makes a big difference anybody got anymore suggestions plz thanks everyone for their time especially rd100 | ||
| | #28 | |||
| Guest
Posts: n/a
| I would be ok with out the wave guide, Have you tried moveing the dish the the lnb in the correct place, The only problem then must be a faulty lnb,
| | #29 | ||
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | put the lnb where it should be before above test do you mean re align dish rd100 to suit feedhorn? cheers | ||
| | #30 | ||
| ASBO Club Member - Persona non grata Join Date: 30-07-2003 Location: Stockholm, Sweden
| No you don't need to realign the dish, i think you have a faulty LNB as RD100 says. They make thousands of these LNBs and you might be unlucky. Contact the dealer you bought the Inverto from and ask to try another sample as you beleive it's something wrong with the one you have. Here is a picture of a Andrew 120 i installed last year, you can see that the feed is placed more closer to the dish than you have now, it's the outer grooves you have to match to the plastic feed bracket. | ||
| | #31 | |||
| Guest
Posts: n/a
| Wow that place looks nice where is it also it looks like azel mount fixed dish if so what is it beening used for
| | #32 | ||
| | #34 | ||
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | is it classed as faulty because its working perfect just slightly less than the maximum i only notice because i am on 7w everything else ok do you think its worth trying an invacom thanks for your time and patience iwol | ||
| | #35 | |||
| Below are my trade prices: Andrew Type 120 Rx-Only OIffset Antenna System, AZ-EL mount p/n 621200050 1pcs - Ex-stock EUR160,00 Andrew Rx Feedhorn p/n 611606007 1pcs - Ex-stock EUR26,00 Andrew Kingpost mount p/n 610012901 1pcs - Ex-stock EUR108,00 | |||
| | #36 | ||
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | hi likvid and rd100 sorry to bug you but ive just been outside (you know what its like)checked the signal on the maximum out ,then i removed the feedhorn/inverto and moved it all over the place and could not get a signal as high as the maximum,is it worth getting a invacom instead as this inverto was only £15 any input once again highly appreciated iwol | ||
| | #37 | |||
| Guest
Posts: n/a
| That's about the same prices i get but they always charge loads for postage,
| | #38 | |||
| Guest
Posts: n/a
| You can try a invacom if you want to but do you want to spend more money, But i have already tested a invacom on my dish and the inverto is better
| | #39 | ||
| | #40 | ||
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | not really but i cant believe a £10 maximun lnb is gonna give me a better signal nthan the £70 feedhorn/lnb ive just bought cheers rd100 | ||
| | #41 | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | You could drive there and pick it up fo less than that. L. | ||
| | #43 | ||
| Specialist Contributor Join Date: 03-04-2003 Location: Kyrenia - NORTH CYPRUS
My System: 3.0m Motorised Channel Master 4 fixed dish SKY_HD DM7020s Vsat Kathrein UFS-910 HD | | ||
| | #45 | ||
| | #47 | ||
| | #48 | ||
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | sorry iceman didnt know you was in cyprus (you lucky thing) have you tried the inverto by any chance.....just wondered what your opinion was on it and is there much difference with the quad against the single c120 | ||
| | #49 | ||
My System: 3.0m Motorised Channel Master 4 fixed dish SKY_HD DM7020s Vsat Kathrein UFS-910 HD | Yes i have tried the tiny C120 inverto...(i think its a joke) Yes,there is a noticable difference between single and quad invacom | ||
| | #50 | ||
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | cheers iceman i too have just bought the inverto and found it very poor with the cm feed horn worse than the maximum 40mm standard lnb i had on originally (see initial post) youve given me a bit of light at the end of the long tunnel | ||
| andrews, big, dissapointment, feed, horn |
