andrews feed horn big dissapointment
Old 07-10-2006   #1
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro
hi just changed from a standard 40mm maximum lnb to a inverto 1.3 and channel master {andrews] feedhorn, only to find im getting slightly less signal with the feedhorn setup.(big Dissapointment) ive noticed that the members pics on here all have the bracket nearest the lnb ,i needed to put the bracket nearest the feedhorn mouth to get the best signal am i missing something obvious and is there a possibility i may have to adjust the dish very slightly for the feedhorn(please tell me yes) any info advice appreciated p.s. i used to get the 7w sat with slight breakup with the old lnb but it really struggles with the new feedhorn ,i use this as a bench mark cheers guys
andrews feed horn big dissapointment-image024-jpg
iwol is offline   Reply With Quote
Old 07-10-2006   #2
picture added
picture added
Old 07-10-2006   #3
ouagadougou's Avatar
My System: 2m NERA Prime Focus Dish for C/ku Bands, DM500, SkyStar2, Technomate 5500CIP, Force 1122.
It looks from the pic like you have a standard 40mm LNB clamp on your dish and this wont necessarily put the new feedhorn phase centre at the focal point of the dish.
You arent guaranteed to get more signal just because you changed to an Andrew feedhorn especially if your original LNB has significantly better performance than the one you have used with the Andrew feed. Performance improvement due to better illumination can be very slight and is best tested with a fringe signal.
Cheers.
ouagadougou is offline   Reply With Quote
Old 07-10-2006   #4
cheers its got a 40 to 20mm adapter which should centralise it wondering if dish may need realighning because of the feedhorn wouldnt imagine the inverto lnb would be any worse than the maximum make i took off
Old 07-10-2006   #5
I dont have a 40mm clamp for my Andrew/CM 1.2m so not 100% sure of the physical difference. You could always measure the focal length with the 40mm clamp and LNBF and then recheck it to make sure the Andrew feed is fitted in the correct place.
Old 07-10-2006   #6
I just compared an Inverto 40mm LNBF and an Andrew/CM feedhorn for my Andrew/CM 1.2m and the Andrew/CM feedhorn needs to be nearer to the dish surface by approximately 5 to 7cm compared to the clamping point on the 40mm Inverto LNBF.
It looks like you are over illuminating the dish with the Andrew/CM feedhorn in a 40mm LNBF clamp.
Old 07-10-2006   #7
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
Is there a ghost signal?
Ie. when the dish moves does the signal go strong, weak, strongest?
If it does then this would tell us that the feedhorn is not directed at the centre of the dish.
Low Profile is offline   Reply With Quote
Old 07-10-2006   #8
thank oaga i can move the lnb forward about 4cm which puts it in the same spot as other members set up but the signal gets worse any idea thanks
Old 07-10-2006   #9
thanks low profile would that be on all sats or just the weak ones, and how would you overcome this cheers
Old 07-10-2006   #10
Rd100
Posts: n/a
First off to start with you do not need to change the lnb clamp as that is the only one andrew do for the dish thats why they supply a spacer you just need to use the 23mm to 40mm spacer that comes in the box with the feedhorn & waveguide and lnb cover,
Next the feedhorn is to far away from dish it should about 2-3cm more to the dish where the three rings are (first ring on its own near the dish and two rings together thats where it should be)
Old 07-10-2006   #11
iceman's Avatar
My System: 3.0m Motorised Channel Master 4 fixed dish SKY_HD DM7020s Vsat Kathrein UFS-910 HD
This is what the focal distance looks like on a 1.20 CM dish using the original CM feed
andrews feed horn big dissapointment-dcp04318-jpg
iceman is offline   Reply With Quote
Old 08-10-2006   #12
Rd100
Posts: n/a
Yes thats right thats what i was talking about, if you are in front of the dish and looking at the lnb holder the first ring on its own faceing the dish thats where thr front of the lnb holder should be,
As in this pic you have posted up that is the same place i alway put the feedhorn and i have installed loads of these dishes and it is the right place,
Also the Andrew & older type channel master feed horn are the same just the andrew feedhorn has a beter feed window as the old channel master one's had a habit of letting in water after a few years
Old 08-10-2006   #13
thanks iceman and rd100 but when i put it where you say the signal is slightly worse the only reason i put it where the pic shows is that the signal was slightly better looks ;like i might try the invacom or put the old maximum back on (have i wasted my money) the guinea pig itry it on is 7w and i can check the signal with a digisat meter......thinks seem to make less sense i thought changing the maximum 40mm lnb to the inverto with feedhorn would be better any suggestions explanations appreciated
Old 08-10-2006   #14
Rd100
Posts: n/a
Here is the inverto on my dish with the feedhorn, It works fine better then any other c120 or 40mm lnb,
can also be seen in this thread
http://www.satellites.co.uk/php-bin/...ad.php?t=69014
Have you had a move of the dish to see if it all is ok,
Also is the feed horn new as there is diffrent types of ku-band feedhorns for the andrews if so what is the part number on the box
Old 08-10-2006   #15
thanks rd100 yes it was new came in bubble wrap but how can you explain the lower signal when you move the feedhorn where it should be cheers
Old 08-10-2006   #16
Did the feed come with separate spacers?
I remember when i installed this dish it came with spacers that had grooves in it so it got exact position.
Also it came with standard spacers with the dish that didn't suit the Andrew feed but only standard 40/60mm LNBFs
Likvid is offline   Reply With Quote
Old 08-10-2006   #17
hi likvid it came with spacers that had a groove which will probably match the feedhorn up in a couple of different fixed spacers either where mine is or where members tell me it should be but like i say when i put it where it should be the signal is slightly lower
Old 08-10-2006   #18
Rd100
Posts: n/a
Like i showed you in the pic just put the feedhorn there and all will be ok,
Like on mine of i move the feedhorn forwards or backwards the signal drops as it is in the correct focal point, If the feedhorn works as it is where it is on your dish there is someting wrong,
What is the model number of the feedhorn it would be printed on the box,
Also did the feedhorn just come in bubble wrap or was it boxed with feedcover and wave guide,
Old 08-10-2006   #19
cheers rd just came in bubble wrap is the will see if no. on feed horn
Old 08-10-2006   #20
found no.of.feedhorn
hi rd 100 the number on the feedhorn is 3040661 if this means anything
Old 08-10-2006   #21
Rd100
Posts: n/a
where did you but it froon as all andrew channel master feed horn come in a white box with the 1X feedhorn 1x wave guide 1x feed cover,
It looks look where you brought if from kept the wave guide and cover, If it was brough from a shop known as a satellite super store they are known for keeping the wave giude and cover,
I have a andrews feedhorn here boxed with cover and wave guide that i ordered in for some one which i got to post out tomorrow,
see in the pdf below the feedhorn you should have and be useing is model number 611-6060-07
http://www.channelmaster.com/pdf/KBANDRX.PDF
Old 08-10-2006   #22
Rd100
Posts: n/a
yep thats the right one just checked right now, its printed on the top of the flange which bolts to the c120 lnb
Old 08-10-2006   #23
hi rd100 great info got to go out now can wwe continue this convaersation later cheers
Old 08-10-2006   #24
Rd100
Posts: n/a
Ok no problem and it is a channel master 1.2m dish you have ain't it,
The only thing that would drop the signal is faulty LNB or Warped dish,
Old 08-10-2006   #25
A bit enthusiastic
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3
Iwol,how much was the difference in % (pic.quality) when you changed the Maximum for the Inverto+feedhorn?
I think your problem is the Inverto lnb,not the feed.I've had very poor results with the Inverto on my Fibo and the Gibertini as well.
The cheapo Interstar GI-201 works a lot better on both my dishes.
So if you are a homebrewer you could always try what I did:
Cut the feed off your Maximum lnbf with a saw and then attach it to the Andrews feed.If it doesn't work (I think it will) the Maximum is so cheap you can always buy a new one.
steffan_st is offline   Reply With Quote
andrews, big, dissapointment, feed, horn
[IMG] code is Off
