hi, help with tuning in sats on tech 7755a please
Thread Tools Display Modes
Old 08-10-2006   #1
My System: technomate 7755 2cvi technomate motor 80cm dish
I have been setting up my motor for several weekends as I had level probs with my pole and other familiar stuff you will all know about if you have installed a motor.
I am now at the point where i am able to choose a satellite from my list and then the usals setting sends the dish to the position of the sat and i do a scan and presto I have channels.
Sounds good???
I have 12 sats stored on usals and before I had aligned my motor correctly I had 10 sats stored on diseq.
What is the difference between diseq and usals??
I now have probs with scanning for new sats as when I try to send the dish to some it tells me my tp is full???
It sounds as though I have reached my limit as to how many channles I can store. I thought this was right until I chose a new sat and it found it moved to it and scanned for new channels and all was ok?
Any ideas??
Also when I input a tp manually it never stores it to the list of pre installed tps??
Any ideas also??
I thought this was an easy reciever to work with but I think I was wrong.
Thanks for reading this and any help is appreciated.
Mat
matluz is offline   Reply With Quote
Old 08-10-2006   #2
Donate to this board
Park Royal's Avatar
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
Delete all radio channels and transponders that do not show strength/quality levels.
PR
Park Royal is offline   Reply With Quote
Old 08-10-2006   #3
thanks that was quick>>>
Yep just went to the kitchen and returned and here we are. I will give it a go.
Thank you
[IMG] code is Off
Forum Jump
