twin lnb problem | |
| Member Join Date: 10-10-2006 Location: Yorkshire
My System: HumaxHDCI2000 Powercampro TPS subsciption card 80cm dish Twin Mono |
Is there anyone who is using a Lemon twin monoblock successfully who can advise me on what I am doing wrong. I have a HumaxHDCI2000 which works fine with a single monoblock and a Technomate 1500CI+ which also works fine on a single monoblock The 80cm dish is focused on Hotbird and Astra. There are two leads both tested leading direct to the Humax and Technomate. When I replaced the Single MOnoblock with the Twin the receivers behave as if it is a loop-through. Where the receiver on one lead e.g the Humax works fine as expected whilst the Technomate is restricted to the frequecy of the Humax, which must be active to receive the signal. I have switched wires, receivers, tried every combination with no success the lnb was swapped for another, still no result. There must be some one who has a solution or an lnb of another type they could recommend. | ||
My System: HumaxHDCI2000 Powercampro TPS subsciption card 80cm dish Twin Mono | Up and working after the third attempt and many hours research. No idea why possibly a loose connection or the threat of returning it from whence it came. Last edited by tcdi; 15-10-2006 at 06:00 PM Reason: spell check | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
I'm glad you are sorted tcdi I missed your original request, I must confess I did read it but did not understand it as a cry for help.
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
