Best DiSEqC Motor ?
Thread Tools Display Modes
Old 13-12-2003   #1
Best DiSEqC Motor ?
What would be your recommendation(s) for the best DiSEqC motor? Best performance (accuracy & speed), and reliability/longevity (build quality, weatherproofing etc.)? (For use with Humax receiver)
TIA.
seret is offline   Reply With Quote
Old 13-12-2003   #2
T24
Info Exec
Stab motor H-H 100 up to 1M dish or H-H 120 up to 1.2 M dish.
T24 is offline   Reply With Quote
Old 13-12-2003   #3
Thanks T24.
Do you have any experience with any others e.g. Moteck SG2100, Superjack DG-120, Cryptic etc.?
Also, how long do these motors last? I have read of some showing signs of wear/play within a few months!
Would an actuator (with V-box?) be the best choice for reliability/longevity?
TIA.
Old 13-12-2003   #4
T24
Info Exec
DG 120 is the best but I think it's hard to get hold off,yes you can use actuator and
VBOX (more stable)otherwise I prefer H-H 100 or 120.
H-H 120 with 1.1 M Triax dish working fine.
ps-Actuator is noisy.
Good luck
Old 13-12-2003   #5
cjgall's Avatar
My System: Topfield 4000PVR with Aston 1.07 CAM, (canaldigitaal), dragoncam, Sky digibox (freesat), Strong FTA box, Visiosat trisat looking at Astra1, Astra2 and Hotbird, Various home built computers, Linux & windows
Originally Posted by seret
Thanks T24.
TIA.
I had a Moteck SG2100 but ended up exchanging it for an Aston motor after a couple of weeks. The Moteck had a will of its own and kept forgetting sat positions etc. With the Aston I have never looked back. I have heard that Stab are also very good.
cjgall is offline   Reply With Quote
Old 13-12-2003   #6
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
Oh dear!!!
I just bought a SG2100...It will be up and running sometime next week. I hope it will be ok. I will post my impressions the minute I have got it running.
__________________
I only believe stuff that comes straight from Mr. Horses mouth
T_G is offline   Reply With Quote
Old 13-12-2003   #7
rolfw's Avatar
As I've said before, had no problems with the Moteck, have installed 5 so far, two with SS2s one with an Extreme, one with an Echostar 707 and one with a Hyundai HSS800ci, the USALS worked perfectly and they continue to function flawlessly.
I think that cjgall must have had a friday afternoon motor.
__________________
Rolf
Donate
Old 14-12-2003   #8
Good luck
Thanks.
I was thinking about the Triax TD110, the aluminium version - is this a good choice?
Also, I'm in Scotland, which is apparently the windiest Country in Europe, so I'm wondering how robust all these DiSEqC motors are?
BTW, how noisy are actuators?
Old 14-12-2003   #9
Originally Posted by T_G
Oh dear!!!
I'll look forward to hearing how you get on with it.
Thanks for the reply.
Old 14-12-2003   #10
PCD
DB Magician
PCD's Avatar
Merlin of the Idiot Guide
I have an Apro SG2100, I believe produced by Moetec, for about 4 months. Installation with a Xtreme was dead simple, still working fine, no adjustments required so far, touch wood !
PCD is offline   Reply With Quote
Old 14-12-2003   #11
T24
Info Exec
@ SERET
Ok,in that case actuator is the best option,Triax TD 1.1 M is a very good dish,use
actuator(super jack 10")its noisy if you mount the motor,dish..on a balcony.
Old 14-12-2003   #12
cjgall's Avatar
Oh dear!!!
I wouldn't worry too much, many people have good experienced with the SG2100. It also got a good review here in the Netherlands
I bought the SG2100 when I first started using sat. Not only did I buy a Friday afternoon motor (or was it a motor that somebody else had previously taken back to the dealer because it was broken?), I also made the mistake of using a dealer that was only interested in make as much money as possible without actually providing any service.
Oh well, live and learn. At least thanks to this board I am a bit wiser
Old 14-12-2003   #13
rolfw's Avatar
LOL, we've all bought Friday afternoon equipment at one time or other, my own personal weekend purchases are Pioneer DVD drives. .
__________________
Rolf
Donate
Old 15-02-2004   #14
russquk's Avatar
rolfw,as you have fitted a few moteck motors,have you found that it fits better to any make of dish perticular.i only ask as i have read that some motors do not fit very well with some dishes.
russquk is offline   Reply With Quote
Old 15-02-2004   #15
rolfw's Avatar
It appears to handle most dishes, there can be a problem if the dish mount is widely spaced, see the attached photo, if the dish mount bolts are as high as where I have marked, they can catch on the "F" connectors and cables, you may need to saw off any surplus.
__________________
Rolf
Donate
Old 15-02-2004   #16
russquk's Avatar
ok,thanks for that,got a moteck motor on order just looking for a dish now!
Old 15-02-2004   #17
rolfw's Avatar
What size?
__________________
Rolf
Donate
Old 15-02-2004   #18
russquk's Avatar
well i might go for triax 88cm dish i think the 1.1m dish maybe to much for the motor,i know it says the sg2100 can take up to 1.2 dishes but i thinking it might have to work a bit harder and wear out quicker
Old 15-02-2004   #19
rolfw's Avatar
It will take a triax 1.1, but only if it is not in an exposed position, looked at one the other week and it was showing signs of wear after the storms, but it was very exposed.
You might also consider the Raven Gemini 90cm, a very nice dish, as is the Triax of course.
__________________
Rolf
Donate
Old 15-02-2004   #20
russquk's Avatar
may have to flip a coin,triax or raven,i must admit i was looking at the gemini dish first,looks like a nice dish!
Old 15-02-2004   #21
GotMyBusPass
Posts: n/a
Sat critics gave a very good write up on the Motek last year. I am collecting one on tuesday as my RotorSat HH100 (a clone of the Stab HH100) is showing signs of wear in less than 2 years. The last lot of gales a few weeks ago appears to have been the main culprit even though I backed the dish into the wind.
Old 16-02-2004   #22
russquk's Avatar
my house is in a middle of wind tunnel i think,the row of houses in front of us got demolished leaving us exposed to the elements,and as the house the made of cheap building materials i will more than likely have to put the dish on a pole in the garden,unlikely i will get a signal in the back garden as there are houses and trees in the way and if i put it in the front garden it will get damaged or nicked.house swap anyone?
Old 17-02-2004   #23
A bit enthusiastic
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3
I have a Moteck too but I have never got the USALS working together with the Humax.//
steffan_st is offline   Reply With Quote
Old 17-02-2004   #24
rolfw's Avatar
The settings can be critical steffan, what are your motor settings and have you filled in the lattitude and longitude information?
__________________
Rolf
Donate
Old 17-02-2004   #25
A bit enthusiastic
Thank you for asking Rolfw
Yes,I added the longitude and latitude but when it didnt work I went back to the Diseqc 1.2 mode.//
[IMG] code is Off
Forum Jump
