2lnb's and moter works? | |
| Regular Member Join Date: 18-10-2005 Location: London
My System: Wave Frontier T90 Dreambox 7020S-Gemini 4.10 8 lnb's | I want to have 2lnbs mounted on my dish but at the same time i want to be able to use my moter. Is that possible with a dreambox 500s? | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Do you mean two LNBs mounted on the same dish as the motor?
__________________ | |||
| Specialist Contributor Join Date: 03-04-2003 Location: Kyrenia - NORTH CYPRUS
My System: 3.0m Motorised Channel Master 4 fixed dish SKY_HD DM7020s Vsat Kathrein UFS-910 HD | | ||
| | #5 | ||
My System: Wave Frontier T90 Dreambox 7020S-Gemini 4.10 8 lnb's | | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | If you want to do that, then you need two dishes, as when you move the motor, the hotbird LNB will move off of Hotbird.
