2 dishes 1 reciever
Thread Tools Display Modes
Old 14-10-2006   #1
My System: SL65 Astra 28 Astra 19
2 dishes 1 reciever
Hi Guys
I have 2 satellite dishes one faced either end and only 1 receiver
Do you know if there is anyway or wheter it is possible to connect the 2 lnb wires into one reciever so i can acces both dishes channel? or is there a more easier way..sorry im a sattelite dish newbie and idiot!
whoimi is offline   Reply With Quote
Old 14-10-2006   #2
Red Hugh's Avatar
My System: Sky Multi-Digital FTA. Quad lnb, 60cm dish. Skystar 2 pvr TV, 1.2m dish, Lnbs x 2 Manual.Technomate 7755 AMD 3000+ 2G CPU, 128 Graphics card, 1024 ram, 150 HD. P4 2.93G CPU, 128 Graphics card, 1024 ram, 229 HD,
A simple A-B switch will provide for, connection of two Lnb's (dishes) to one receiver
Red Hugh is offline   Reply With Quote
Old 14-10-2006   #3
rolfw's Avatar
If it is an analogue receiver, then as Red Hugh says, use an A+B switch, if it is a digital receiver, with DiseqC switching, then a 2 way DiseqC switch can be used.
__________________
Rolf
Donate
Old 16-10-2006   #4
Where can i get these from any ideas please
yes its digital receiver? what do they cost and what exactly do i look for anyone got any links please
Old 16-10-2006   #5
rolfw's Avatar
You can click on our advertisers at the top of the forum, Pulsat do the Global DiseqC switch, Mantesat do a couple of choices.
__________________
Rolf
Donate
Old 16-10-2006   #6
:d
Thanks all
would something liek this do?
http://www.maplin.co.uk/images/full/a08ft.jpg
SO i assume the 2 points i connect both the sat leads in there and the one on top is the connection to reciever? what type wire / cable will i need to connect to the switch to receiver thanks
also one more question how would this thing work
example say i have the following channels configured to each dish..when i go to channel3 and 2 will it automatically pick up channel 3??
ch 1 - DISH 1
ch2 - dish 1
ch3 - dish 2
ch4 - dish 2
Old 16-10-2006   #7
rolfw's Avatar
No, that is two way splitter, the switches I have linked to are DiseqC switches.
What receiver do you have? If it is a DiseqC receiver, then it is easy to set up so that it will automatically switch to whichever channel on whichever satellite you choose.
PS. The more information you supply, the more useful the replies are likely to be.
__________________
Rolf
Donate
Old 16-10-2006   #8
I have one of those recievers which came with a Lidl Dish...
lol sorry im quite a n00bie on dishes :$
Old 16-10-2006   #9
rolfw's Avatar
Ok, a Silvercrest, that should be easy to set up, you simply go into the satellite menu and allocate the two satellites with DiseqC A and B, then the receiver will switch seamlessly when changing channels.
You can connect the cables to the switch somewhere between the dishes externally and then use the existing satellite cable into the house. If you don't have an existing cable, then use a good quality copper shielded satellite cable, you can get it from Maplin or B&Q.
If you go for the Global DiseqC switch, then it has a waterproof cover, the other styles need waterproofing on the connections with self amalgamating tape or similar, as do the LNB connections.
__________________
Rolf
Donate
Old 16-10-2006   #10
Thanks for that mate!
Basically both the Wires from the satellite dish come thru the wall into the Living room, at the moment im just having to go at the back of the receiver and manually change the wire.
So with this switch I can use it indoors right? All I need to do is get the 2 LNB cables and connect them to that switch then get another LNB Cable (short I assume?) then connect it from the Swtich the receiver is this correct?
Old 16-10-2006   #11
rolfw's Avatar
Yes, exactly that.
__________________
Rolf
Donate
[IMG] code is Off
Forum Jump
