Prime focus dish with a H-H motor? | |
| Member Join Date: 03-01-2004
Hello, Is it possible to mount a small (120cm) prime focus dish to a H-H motor originally designed for offset dishes? If I manage to adjust correct elevation angle to the prime focus dish, is the arch that the motor provides adequate? The size of the dish should not be a problem since the H-H motors generally support dishes with diameter up to 120cm. Thanks, Martie | ||
| Yes it is, but the bracket you have to make, should mimic the elevation offset of the particular antenna design that was in the design of the original mount, which then negates the 20 - 28 degree adjustment in the mount. Why not sell the offset mount and by a polarmount with the proceeds ?
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| The reason why I would like to keep my curernt H-H diseqc motor is that I can control it directly from my PC's DVB card via the coax cable with a little diseqc1.2 utility embedded into the viewing software, it all takes place over a single cable, the dish moves autaomatically as I click on the channels, which I find really handy. Talking about polarmounts, I heard they are a bit more cumbersome to control. Is it possible to control them with diseqc1.2 signals or do they depend only on standalone positioners w/ 38V? | ||
| Specialist Contributor Join Date: 01-01-2000
| There several Mounts that can be used diseqc1.2 signals that will accept a prime focus dish. which make of dish do you have ? Please be aware that many however do not cope well with 1.2 dishes. Please confirm your dish make so that we can help futher regards Old Satellite | ||
Similar Threads | ||||
| How much worse is prime focus? | Sool | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 1 | 19-05-2006 11:45 AM |
| 1.5m Offset Vs 1.8m Prime Focus ? | tux233 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 18 | 20-11-2005 12:26 PM |
| Offset or Prime Focus?? | Indasol | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 2 | 03-02-2004 09:04 PM |
| single feedhorn for 1.80m Channel Master Prime Focus | jacqfranc | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 02-02-2004 11:05 AM |
| BBC Prime broadcast in Serbia and Montenegro | net1 | Daily Satellite and Broadcast industry News | 0 | 11-07-2003 08:05 PM |
