mesh dish v solid dish
Old 15-11-2006   #1
handyman 44's Avatar
My System: sky digibox also technomate tm 1000 ci motorised 80 cm dish
just wanted to know if there was a perfomance differance between a 80 cm mesh dish and the same in solid dish .as i was trying to pick up tthe s1 cannels on turksat .i used a online dish caculator and it recommended a 60 to 80cm dish so i used a 80 cm mesh dish .i can get the west beam channels but not s1 .the channel i was interested in was show turk and euro turk . many thanks
handyman 44 is offline   Reply With Quote
Old 15-11-2006   #2
Donate to this board
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
Just checked with a contact in Gt Yarmouth. Both channels AOK, 85 X 90 cm dish.
PR
Park Royal is offline   Reply With Quote
Old 15-11-2006   #3
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos there's no room for dishes here... :(
The Sleepy Hollow pollracle has spoken!
It'd be best to check your dish's alignment & LNB skew just to make sure your focussed on the satellite properly...
As for Mesh vs. Solid, well, there's a thread in Einsteins Alcove on that topic:
mesh vs solid dishes
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
(though the latter no longer fits due to my ever expanding waistline!!!)
Resident KIRBY Vacuum nut...
2cvbloke is online now   Reply With Quote
Old 16-11-2006   #4
yea read the very long thread about mesh dishes and still no wiser on that one the dish arrived to me by the white van man the box in the useual condition so im thinking may be its slightly out of shape .in future i think i will order larger dishes than i need to compensate for the van man .think i get a 90 cm solid dish .as theres no more signal strenth coming from this dish.many thanks
Old 16-11-2006   #5
Always reject delivery of goods if packing is damaged. Write the reason on the drivers delivery sheet then inform seller straight away.
PR
Old 16-11-2006   #6
never there when he comes but u are right .thanks for your help.
Old 20-11-2006   #7
just fitted 1meter dish and it to is out of shape it looks ok but still no s1 beam channels .so i drilled hole in bottom of dish cable tied it to lnb arm stretched it back into shape now the bottom half of the dish is also reflecting the signal on to the lnb .and it works fine.the box that the dish arrived in looked fine .maybe a manufacturing fault .if any one is using these cheap pressed steel dishes .its worth just slightley flexing the dish .after its been alinged to see if more signal can be gained.
Old 20-11-2006   #8
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
what make of dish is that ?
Old 20-11-2006   #9
triax 1meter pressed steel grey solid off set lnb
dish, mesh, solid
[IMG] code is Off
