usals or diseqc 1.2 ?
Thread Tools Display Modes
Old 22-11-2006   #1
wod
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish
right installed my system other week and when in the settings whats the best to use usals or diseqc ?
because when i choose diseqc 1.2 and move from say 19e to 16e i lose signal but when using usals i can move between sats fine but the signal is quite low 76% on some channels, worse on 16e
is my dish too small for sats like 16e or is my alignment off some how
when it was first aligned the signal was like 86% for astra 1 &2 and reasonable for 16e as channels like fox crime was 74% and my music 60 ish
also the lnb postion where should it be, pushed up to the collar or what ?
thanks
wod
Old 22-11-2006   #2
handyman 44's Avatar
My System: sky digibox also technomate tm 1000 ci motorised 80 cm dish
the lnb should be vertical try sliding lnb in and out to optimise signal strength .
handyman 44 is offline   Reply With Quote
Old 22-11-2006   #3
wod
i have the lnb a quarter of an inch from the collar which seems best position
was going to try other lnbs to determine best one for my setup
seems i need to tweak it abit as art tp is 55% signal strength on hotbird
Old 31-10-2007   #4
My System: Arion hd8000 Aquos 32 hd tv Denon 2807 Qaccoustics 1010 sys Toshiba ET1 Toshiba HDE1
Wod
I have exactly the same problem you described last year.
I am new to motorised and wonder what was the eventual fix for this.
I suspect a reset of all hardware and search and store with Diseqc only.
Mine works fine with usals but loses sats when in diseqc and some wont store.
Cheers
JohnRaymond is offline   Reply With Quote
Old 31-10-2007   #5
My System: Humax 5400irc 80cm Dish Invacom 0.3 LNB ToH 3.3 5.7. P4 Xp home 3.2 pro.
Hi wod.
USALS is good, but in Diseqc you can tweek you dish.
Goto 16e (No Signal) I think you get.
Go into your menu...Motor Settings, set to Diseqc,
and in there someware is Motor moving. It will move your motor
East or West (Tweeking motor).
Once you get the hang of that you can goto all the Sats and
fine tune for the best signal quality.
BF...
Bbigfoot is offline   Reply With Quote
[IMG] code is Off
Forum Jump
