Is a dish just a dish? | |
| Regular Member Join Date: 25-05-2003
Hi I am looking to buy a new dish about 90 cm and having seen that there are a great deal on offer at different prices what i would like to know is, is there a difference in the performance from one dish to the next? Or is a dish just a dish? thanks | ||
| Dishes vary on performance and on features Mesh is normally less effective as solid, but is easier to camouflage Fittings could be wallmount only, post mount, or with option of motor drive Make sure you buy one that has what you need (if you are upgrading for motorised later you might want one that can fit a polarmount )
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| | #3 | |||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 |
PaulR | |||
| Where on eath did you get the info of 1/2 a wavelength ? Whoever wrote that needs to be strained through one of their dishes
| | #5 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | isn't it also the type of material used in dishes as how come some are steel or aluminum and channel master dishes are like some type of plastic ? also i read that some 80cm dish could outperform even a 1metre dish for signal gain was in a magazine or is that some bs ? | ||
