MR on Strong 4375 (& Hispasat)
Old 17-01-2004   #1
Godzuki's Avatar
My System: Dreambox 2075+ Stab RotorSat 120HH 60cm ex-$ky mesh dish LG 32" HD LCD w HDMI + DVI-in XCcube EZ18 GeForce ??? 128MB DVI-out LeadTek PVR2000 4 x ~500GB HDDs Creative Inspire 5300 5.1 Creative DDTS-100
I've been lurking for a while now but can't seem to find the info I'm after.
My setup consists of:
Strong SRT-4375, MR CAM (1.055), Stab RotorSat 120HH motor,
60cm mesh dish (ex-$ky analogue) & Cambridge Platinum 0.6db LNB.
I am located near Liverpool (Longitude:2.8, Latitude:53.4).
I was hoping I could get some help with a few queries.
1) Does MR CAM (1.055) work on Strong 4375 without replacing IC (U206)?
2) With updated keys, what channels should I get from Hotbird/Astra 19.2?
3) Should I get a flicker of a signal at 30w on 60cm mesh dish & 0.6db LNB?
Any comments would be appreciated, TIA.
Godzuki is offline   Reply With Quote
Old 17-01-2004   #2
Irish Mod
Razor's Avatar
Full list of MR channels here
http://www.satellites.co.uk/php-bin/...ead.php?t=8529
As for a signal from 30W with 60cm dish....Not sure but would say no.
Will MR work in your box....Ask them before you buy.
Also...Lurking is ok for a while, but after a while you just have to dive in.
Don't mind my spelling
Razor is offline   Reply With Quote
Old 18-01-2004   #3
Godzuki's Avatar
Razor, Thanks for the pointers.
MR CAM doesn't seem to decrypt some(all?) of packages mentioned, I may have to replace that IC. Will take this issue over to MR forum.
I've had the 4375 for over 2 years and MR for 3 months, so "ask them before you buy" isn't a realistic option.
Guess I'll also be upgrading to a bigger dish then.
Cheers.
Old 02-02-2004   #4
Godzuki's Avatar
At Last!
Just got my 4375 (with u206 replaced) back from local TV/Sat shop (cost £10).
Wow! I can decode channels again!
This hardware fix seems to work a treat, now I need to apply the software fix.
Carpe Aptenodyte!
Old 30-04-2004   #5
Angry strong 4375
where can you go to get your receiver upgraded to work with Magic Module?
mike501 is offline   Reply With Quote
Old 04-05-2004   #6
I have the same problem
Did you get MR to work on your strong 4375?
4375, hispasat, strong
[IMG] code is Off
Similar Threads
Strong 4375 upgrade refinechange Receiver software, international Section 5 30-01-2008 02:07 PM
Que canais ha em sinal aberto? soprano53 Kaon 2 03-08-2006 06:03 AM
Novas frequencias no hispasat 23/05/2006 filtro Instalações de Antenas & Frequências dos Sats 1 24-05-2006 07:49 PM
Hispasat lobbies for a Digital +'s contract net1 Daily Satellite and Broadcast industry News 1 15-08-2004 07:12 PM
strong 4375 problems installing for analogue ronn DISH SETUP: Single sat, Multi-Sat & Motorised systems 5 02-02-2004 08:34 PM
