cheapest way to add 3rd receiver | |
| Member Join Date: 04-03-2006 Location: UK
My System: Astra/Hotbird |
hi, i've got a twin monoblock lnb feeding two receivers. i would now like to add a third receiver. what would be a cheap way to do this? e.g. get a quad monoblock lnb, multiswitch, etc.? i'm really looking for the cheapest solution. any comments are welcome. cheers, marty | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Looks like a quad monobloc will do what you require.
__________________ | |||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The only problem with an A+B switch, is that you will only be able to use one receiver at a time on the shared line. _http://www.satcure.co.uk/accs/page1b.htm
| | #5 | ||
My System: Astra/Hotbird | | ||
