Newbie needs advice | |
| Member Join Date: 16-01-2007 Location: west Lothian. Scotland
My System: 1.2m dish and lg decoder |
Hi all. I have just purchased a second hand 1.2m Channel Master dish, from a friend, but he has dumped the manhattan starlight decoded. He told me that I will have to buy a new decoder with a built in positioner, to move the dish. Can anyone point me in the right direction on what decoder I will need, to get up and running. Cheers. Scooby5654 | ||
| Member Join Date: 04-12-2006 Location: Blackburn,Lancashire,England
My System: Sky+/Grundig decoder. Technomate TMS1500 ci+/1 metre Gibertini Aluminium dish/Smart Titanium .02 LNB/Moteck SG-2100A,1.2 DiSEqC,USALS motor,all wired in Webro WF100 cable. | Technomate TMS 1500,well supported and very easy to use. | ||
| | #3 | |||
| lifes not a practice run Join Date: 27-09-2006 Location: torfaen south wales
My System: technomate diseq 1500ci+ ibm thinkpad |
deep joy dave Last edited by 4dbennett; 17-01-2007 at 05:42 PM Reason: mis-spelling | |||
| | #4 | |||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! |
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
| | #5 | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | I would have thought he was using 36v actuator, as a disec motor would be too small for a c/m 1.2m If thats the case your going to need a stb with a 36v positioner.
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
| | #6 | ||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | That's what I was thinking, a TM1500 with a VboxII in there should be ok shouldn't it?
| | #7 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Ye any disec stb would be ok with a V-boxII
| | #8 | ||
Thanks guys. The dish has a DiSEqC motor/actuator fitted, but I can easily change that. Not long to pay day so i will get the stuff ordered up, and then have a go at setting it up. Thanks to all for the advice. Scooby5654 | ||
| | #9 | ||
| Regular Member Join Date: 31-05-2006 Location: glasgow
My System: 1.2m motorised qualitv decoder manhatten blind search decoder echostar 3600ip | I would try to get your hands on an echostar 3600 along with a polarmount and an actuator about 18 in depending on what you want to view satwise | ||
