Windy! Anyone else got a dish in the wrong direction! | |
| Mad Scientist Join Date: 29-07-2005 Location: UK
My System: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB. | DOH! Came home tonight and just checked the roof tiles are still on, had one replaced earlier this week from last weeks wind, and either 19.2 has moved... or I have some wind adjustments! Anyone else have a dish now pointing in a new direction?! Paul | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | At least your dish is still up!!! ![]() Just glad I have no dishes outdoors, otherwise I'd probably have lost them by now... Have fun putting it back into place...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | ||
My System: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB. | Yeah thanks for that ![]() I had some expert help the first time so suspect the motor to pole is sound, so I am pretty sure either the dish to the motor bracket has slipped, or the motor itself has jumped some gears and spun round. Its a bit dark at the moment, have to have a good look in the morning. I know it was today as well, as I was watching CNN news this AM and it was find, little bit of breakup every now and again but mostly solid as a rock. Time to get the ladder out at the weekend then! Wish I had the space to have ground level dish - much easier to work on! | ||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Best thing to do in wind like today's is to stow the dish so that the dish's side is against the wind, that way the wind should just blow around it like the rudder on a ship... ![]() Of course, I've never had to do this as I've never had a motorised dish...
| | #5 | |||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide |
__________________ Oldgeezer | |||
| | #6 | ||
| Guest
Posts: n/a
| I am in south wales on the side of a mountain and have seen a few trees and aerials down around my area today but my 1.2m andrews is solid as a rock but then again the andrew's is a professional high grade dish and ain't going no where , But in hurricane winds the andrews dishes below 2.4 should be moved as it says in the pdf below http://www.andrew.com/search/docviewer.aspx?docid=7035 Last edited by Rd100; 18-01-2007 at 07:49 PM | ||
| | #7 | ||
| Regular Member Join Date: 19-12-2005 Location: Derbyshire, England
My System: comag sl65 (x3) Sad but I like them :-) comag porty II (camping) Pace Prima (analogue) Assortment of dishes. computer: Shiney new Acer | God knows how, but my Porty dish supported on the back bedroom window with its suction cup mounting hasn't moved an inch!!!!!!!!!!!!!!! Flapping about a bit yes, but I'm sat watching Eurosport on 19e (analogue) and it's one of the best pictures I've had in ages :-)
__________________ The caravans are coming. Happy Traveller. | ||
| | #8 | |||
But the suction cups are amazing!!! I had it stuck on the windowsframe indoors, and it refused to budge, but it made the paint underneath bubble up...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
| | #9 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Glad I installed my dish to a new location and higher up on Tuesday. Today has been a severe test on the installation, and would have found any weaknesses. No movement laterally or otherwise, just the usual wobbling of the dish in the gusts. Glad I opted for a 3 inch dia. pole Llew | ||
| | #10 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | mines moved and looks like its bent but i'm in a very exposed location dishes with polar mounts are these stronger as the mount fixes the dish somehow ? as you never hear of these moving about | ||
| | #11 | ||
| Member Join Date: 14-08-2006 Location: Wirral
My System: Technomate1500ci super with 78cm dish fixed on Hotbird | My triax 78cm dish was originally set up on a temporary tripod arrangement (a cement mixer stand). If you know the new triax design, it is very easy to assemble and goes up quick, great until the wind pushes your dish over and the swinging arm hits your dish, destroy's your LNB and dints your dish! So armed with home made brackets (unistrut) and 10mm threaded rods bolted through the wall of a brick outhouse, an old scaffolding pole and the usual clamps it has survived the high winds experienced today, result! I will replace the dish later this year and go up to 90/100cm, what's out there, that other members can recommend? | ||
| | #12 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Its TOTALLY calm here
__________________ | |||
| | #14 | ||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | It seems that most of the bad weather hit us lot down here, 8 deaths total, 5 of them here in Lancashire!!! Luckily, I don't think any were caused by stray dishes...
| | #15 | |||
| | #16 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Storm lashed? http://www.xcweather.co.uk/
| | #17 | |||
My System: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB. | So 19.2 is almost parrallel with the wall, problem is Dish is on side that is tunnel-like with next door's wall. Better than 30w though which points the dish almost full on into the wind like a sail ![]() I am sure its easy to fix, once the wind stops, its my fault really as I was onyl commenting to someone in the office today how strong the signal is as when it was setup I am pretty sure it was spot on! Well the power just went off so even if the dish was straight I could still not watch TV | |||
| | #18 | |||
| | #19 | ||
My System: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB. | Not sure thats right, it says 31MPH under the arrow nearest to me, yet the wooden gates at work on the rubbish bin area in the car park ripped there somewhat solid mouting off and were flailing in the wind, waaayyyy more than 30mph to do that! Recomendation for securing flailing gates - US kettle leads, the plugs are useless here and we had a box of them at work, one tied at the top, one at the bottom, problem solved ![]() Well at least secured long enough for the working day to end and me to move my car to a safe distance | ||
| | #20 | |||
My System: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB. | If B&Q are stil knocking out those generators at about 100 quid a go I am sure they are going to make a killing | |||
| | #21 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
The power went off 3 times at work and the network and tills just kept on working as the 4KVAC ups ran all the back office and tills without a hiccup, the owners wanted to know why the electric was going on and off not why the tills and network were still running thus giving uninterrupted sales. What does one have to do to impress your boss? Still the UPS has paid for itself many times over since it was installed 7 years ago. Servers and PC's for that matter do not like losing power, sometimes they don't want to restart.
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #22 | |||
![]() The big one is hooked up to my main PC, but is occasionally used for electrical experimentations (just so I don't blow up the electrics in my house!!! )...
| | #23 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Ive just been reading the German Transponder News forum. One lad had lost the roof off the house but his sat reception is still perfect! Some impressive pics here
| | #24 | ||
| Member Join Date: 12-01-2007 Location: Suffolk, UK
My System: Manhattan Plaza 450 fitted with PVR, motorised 1 metre dish, Universal lnb. |
Just before Christmas I thought Sky had moved following a gale. I didn't appreciate what the cause was, so contacted a local installer who eventually turned up 2 weeks later, inspected the dish from the ground, pronounced it fine, and retuned 3 satellites, and left me to fill in the gaps. I actually bought a new receiver and have struggled for the past 3 weeks to fine tune all the sats it could receive. Like many other parts of the country, Suffolk had a fair old storm today, everything seemed to have survived outside, so settled down to watch Sky, and there it was gone yet again! Luckily I had a written record this time of every counter reading for each satellite, so shouldn't be too painfull to restore it all again by adding the number of revolutions that it was out. Question: If it has done it twice now, does this mean a worn / faulty actuator rod. Sadly I can no longer climb long ladders so need to have an idea of why this has happened because presumably left to its own devices, it will happen again at the next gale. I will probably have to look for a new engineer and suggest what the fault was and not leave him to find an easy way out. I appreciate a comment previously by a member that it is best to turn the dish sideways on, unfortunately the gale started from the SW, but veered WNW mid afternoon with gusts on my wind gauge of over 60 mph. I considered turning it, but decided that I might be asking for trouble against a gale of that ferocity. Cheers Peter | ||
