motor Manhatton HH140alu
Thread Tools Display Modes
Old 19-01-2007   #1
shane77's Avatar
My System: sky + TM 1500CI 31.5W - 39E
Hi does anybody know where the reset button on this is please?
shane77 is offline   Reply With Quote
Old 19-01-2007   #2
Donate to this board
Park Royal's Avatar
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
That motor does not have one. Just 2 buttons only, drive east and drive west.
PR
Park Royal is offline   Reply With Quote
Old 19-01-2007   #3
shane77's Avatar
PR
I can't get above this motor so I'm looking up at it from below, where are these?Any pics? PDF's?
Cheers
Old 19-01-2007   #4
Oldgeezer
johnsattuk's Avatar
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
Most of the motors don't have a reset button as such, it would be to easy to accidentally reset.
There is often a small hole to enable you to prod the reset switch with paper clip or such.
__________________
Oldgeezer
johnsattuk is offline   Reply With Quote
Old 19-01-2007   #5
Oldgeezer
johnsattuk's Avatar
Tech sheet
__________________
Oldgeezer
Old 20-01-2007   #6
shane77's Avatar
Originally Posted by johnsattuk View Post
Tech sheet
Thanks for that but I've already seen it, it doesn't show buttons/reset etc, I'm starting to think there isn't any, sat man isn't coming until Wednesday I'm guttered
His words not mine ''if you get the system and fitting from me the parts as well as well as the fitting is guaranteed for a year'' so I can't even go out and but new. Its been suggested that the parts in the motor are plastic so I think they may have gone so it should be covered.
Can somebody tell me if the hatton fight was good.
[IMG] code is Off
Forum Jump
