preventing diseqc motor brackets moving on pole
Thread Tools Display Modes
Old 20-01-2007   #1
wod
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish
i have a moteck motor and it there anything i can do to stop the motor moving about the pole in windy weather ?
would some sort of clamps above and below stop it ?
also the bolts are starting to rust, i've sprayed them with wd40 is there any place to buy stainless steel ones ?
thanks
wod
Old 20-01-2007   #2
Oldgeezer
johnsattuk's Avatar
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
thanks
wod
I know it's a bl**dy nusiance when it moves, but if the wind is strong enough to move it, it may well be strong enough to break gears etc. it if it cant move
I use stainless nuts and bolts quite a bit, I dont know about 'U' bolts but you can get st.st. screwed rod quite easily. Get mine of Ebay
__________________
Oldgeezer
johnsattuk is offline   Reply With Quote
Old 20-01-2007   #3
Rd100
Posts: n/a
Glue it to the pole LOL.
wd40 dont stop rust best to get some zinc nuts and bolts from a diy store
thanks
wod
Old 20-01-2007   #4
wod
i dont think u bolts would fit if i got some from b&q because of the shape of them
just need to make sure it cant move about as there only so many times as the bolts are so tight now
i should really go 36v with it being exposed but i'm not sure i can setup a polar mount/actuator
Old 22-01-2007   #5
wod
can anyone tell me what size the nuts are on the bolts of the moteck bracket
looking to get some stainless steel ones
thanks wod
Old 22-01-2007   #6
Oldgeezer
johnsattuk's Avatar
thanks wod
Nuts & bolts are M8 13mm A/F spanner
__________________
Oldgeezer
Old 22-01-2007   #7
Nasty Dish Obsession
Lancelot's Avatar
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H
...And thou were the truest friend to thy lover that ever bestrad horse..."
You could put some motorcycle chain lube on them, goes on like WD40 to get into all the gaps but changes to a sticky grease after a couple of mins.
L.
__________________
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
Old 22-01-2007   #8
wod
will these be ok 170070295140 as the current ones are rubbish
grease that reminds me never bothered to do that on the bolts
Old 23-01-2007   #9
Oldgeezer
johnsattuk's Avatar
Those would be OK, dont need nylock but would do the job OK.
Unless you need that many nuts this may suit 170071654057
__________________
Oldgeezer
[IMG] code is Off
Forum Jump
