Urgent: Motor moving the wrong direction | |
| Regular Member Join Date: 29-11-2006 Location: Cheshire
My System: 1.2m CM, 36v Positioner, DB7020Si. Diablo, CAS3+ |
Setting a dish up for a friend, when i move the dish east the motor moves west. Technomate TM-1600 and a technomate tm-2100A (motek clone) Anyone any ideas? Thanks | ||
| Super Nutty Mod Join Date: 03-10-2003 Location: Essex
My System: Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka ! | Are the two cables connected to the motor the right way round. i.e. LNB cable to LNB connection, and receiver cable to receiver connection. Hope this helps as I've never heard of this problem before, there again I'm only young.
__________________ If anyone wishes to copy the Madeleine appeal please feel free to do so. ![]() | ||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | I got this behaviour deliberately once with a 2100, I was experimenting with a mount where the motor was fastened to the dish and the shaft was stationary, so needed to work in reverse. ![]() I rotated the body of the little motor inside 180deg in the PC board, thus reversing the the direction of the motor. If this is a new 2100, there is a posssibility that it has been erroneously assembled that way, if it's a motor that has previously been working correctly, a bit more puzzling
__________________ Oldgeezer | ||
My System: 1.2m CM, 36v Positioner, DB7020Si. Diablo, CAS3+ | Scratch the above i was being very dense, thought west was the other way. Much easier when you have a compass. On another not, USALS is superb, and that technomate is really good, it's soo quick to both opperate and change channels. Makes my humax look antique. Rgds PJ | ||
