Two receivers with one motorized dish | |
| Regular Member Join Date: 06-12-2002 Location: Amman - Jordan
Good day to you all I have an old digital receiver with built-in 36v positioner and I'm planning to buy a new on with CS capabilities but does not have a built-in positioner. Is there a way to use the old receiver's positioner with the new one? Thanks a lot in advance. Ayman | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Just run the old STB with the new one, leaving just the motor/pulse wiring on the positioner connections, using that STB for driving the dish. You can always loop the LNB output from the new STB to the old one if that one requires the signal for peaking to the satellite. Llew | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | not thought of using a vbox with your setup ? | ||
