Diseq to 36V | |
| Regular Member Join Date: 20-08-2006 Location: South East England
My System: Technomate 1500 ci 90cm Gibertini Inverto Silver Tech 0.3lnb Moteck 2100A motor |
I am surprised that someone hasnt designed a convertor that sends a diseq signal to a 36v motor (with the correct power cables of course). This would be the obvious answer for bigger dishes without a vbox. | ||
My System: Technomate 1500 ci 90cm Gibertini Inverto Silver Tech 0.3lnb Moteck 2100A motor | It is. but its indoors. If I had one more box it would tip the marital hapiness balance. | ||
| | #4 | |||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | ![]() I think there's 2 VBOXs, one is just a positioner with a remote control, whereas the second is the converter for DiSEqC to 36v...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
| | #6 | |||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | I have run one up in the loft.
__________________ Oldgeezer | |||
| | #7 | ||
My System: Technomate 1500 ci 90cm Gibertini Inverto Silver Tech 0.3lnb Moteck 2100A motor | The idea was just as a back up if the diseq motor got tired with the new dish i've got. It should be OK. If not it looks like I could be into about another £150+ with the vbox11, a H-H mount and actuator, Oh and 4 way cable. | ||
| | #8 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | yeah but you will have less amount of realigning the dish in windy weather i wish i had gone that way first off, stupid Ebay | ||
| | #9 | ||
| Most of the VBox installs I did were in the loft, running off the same supply as the TV aerial amplifier. Works a treat, as long as the motor outside is also up to the job, (no Minijack/Superjack III s).
__________________ There is a very fine line between "hobby" and "mental illness" | ||
