Ninety Centimetre Sat Dish - What Can I Recieve? | |
| Member Join Date: 21-01-2007 Location: Sheffield, UK
My System: Currently none. |
Im looking to recieve free-to-air satellite televsion. I live in South Yorkshire, Sheffield to be precise. I would not like to get a bigger dish than 90CM unless I could achieve a significantly better quality picture or recieve an additional satellite, if that was the case 1M dish would be maximum. I am aware that there are many, many satellites out there but i'd like to know which ones I could recieve using my dish size and many LNB's and what channels the satellites broadcast. Many thanks. | ||
| | #2 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | If you are looking for the most channels then 13E & 19E are the main European hotspots. A 90cm dish would allow you to have both with an offset lnb, plus another offset on 28E for the free channels there if you so desired.
__________________ | |||
| | #4 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Astar 1D stuff no problem 90 cm is too small for the stuff on Astra 3A though
| | #5 | |||
| Regular Member Join Date: 18-10-2005 Location: London
My System: Wave Frontier T90 Dreambox 7020S-Gemini 4.10 8 lnb's | | |||
| | #6 | |||
| Mad Scientist Join Date: 29-07-2005 Location: UK
My System: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB. |
This should answer your question on what size for 23.5E: Astra 3A, UK Reception and Dish Size Map I am in the south east and can't get a decent signal with my ~80cm. Paul. | |||
| | #7 | ||
| Member Join Date: 23-08-2006 Location: Liverpool.
My System: Echostar 3600via. |
I have a motorised 80cm. mesh dish in Liverpool,i can receive almost everything on it.All Hipistat,Sirius.Thor.Astra,Hotbird,Astra2,Sesat,Tu rkstat,and more.So having a small dish is not bad.I have a Syntech 2000 .3db.lnb. | ||
| | #8 | ||
| | #10 | ||
| Member Join Date: 19-12-2002 Location: London
My System: Dreambox 7020 250g& Triax 90cm ,Technomate 8000 HD , Echostar AD-3000, Superjack VBOX2 Triax 1.1m LNB Lemon mono block | Hi Ferguson, If you are fix mounted and mounting many LNB's then I would mount .Astra19deg,Hotbird 13 deg,Astra2b 28 deg,. For this set up a Lemon monoblock so you rx Hot bird 13 and astra 19 deg . and fix another at 28 deg. If you motorise then Sesat,Turkstat,Hipistat,Sirius.Thor but you need a good sight to obtain a view of all these sats 42 deg east to 30 deg west. At the moment I am on astra 19 most of the time with motorised setup . The triax 90 cm over 1.1. does not pull in much more as I have both going on motors. Cheers I would | ||
