my dish is not moving | |
| Member Join Date: 30-04-2006 Location: uk
My System: dell |
Hi every one. I am new in this forum. I have Manhattan ST Plaza 550 with internal positioner. It has been working fine until few days ago when I tried to change satellites from Hotbird into Arabsat, the dish moved a little bit then stopped dead, I was not able to get any channels from Arabsat but on searching I it came up with some channels from Astra 26. On selecting Astra 26 from the menu all of Astra channels were there. The dish refused to go back to Hotbitrd and although the on screen menu says the dish was moving the actual dish was not. I unplugged the reciever from the mains and replugged it without any success. Is it jammed or a motor failure or a fuse some where? Thanks for any help | ||
My System: dell |
Hi I took the plunge and called in a satellite engineer, the fault was actually with the actuator, which had been working faultlessly for about 11 years! I had pay 104 Pounds to replace it. It is now working fine. By the way, the Plaza 550 with internal positioner has been serving me without a problem for the last 2 years! I would recommend it Jassani | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
We are glad you are sorted with that, it seems to be a bit steep that price
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
