Decided on receiver.....what next? | |
| Member Join Date: 04-01-2007 Location: Scotland, UK
My System: None yet | I'm new to satellite systems and looks like this is going to be the start of a new hobby... ....so I've spent a long time deciding on what receiver I need and looks like its going to be the Dreambox 7025. Now I need to start to think about the rest of the system... I know I want a motorised dish and I know that I can install up to 90cm without planning permission. The rest is a gaping void of what I do not know. And as a famous defence secretary once put it, I'm not sure that I know what I don't know. And that is where you experienced guys on here come in.. My questions are..... - What should I be looking for in a satellite dish that will make the most of a dreambox ? - Is it easy to buy the dish and associated equipment (cables, etc?) in one? - Any recommendations of where to buy? - Do I also need to buy a satellite finder? After this my plan is; - Buy system - Try to install - Swear lots - Read the stickies on here about how to install - Realise that I should have read that first and then try again to install - Get it 'sort of' working - Accept this for a few weeks as I am fed up with it - Wife moans that we cannot get Channel 4 any more and she cannot record Coronation Street - Swear lots - Come back to the forum with more questions - Have a state of the art system that works perfectly. Thanks guys,,,, | ||
| | #2 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Dreamboxes are wonderful beasties but take time to learn. Only consider them if you like a bit of a challenge and are prepared for some headaches. ![]() Good choice though - although remember the 7025 isnt as well supported as the 7020 or 7000, although it does score with having the extra tuner facility. And yes your plan sounds about right.
__________________ | |||
