Linear actuater
Thread Tools Display Modes
Old 03-02-2007   #1
Linear actuater
I have a prime frocus dish which was previously motor driven. The linear actuator is still attached ( the green rod in the picture). Are there any reasons to keep it in place or can it be removed ?P2030083.JPG
bodge is offline   Reply With Quote
Old 03-02-2007   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
If you are using the dish in a fixed position you'll need some form of dish locking bracket to centre it in relation to the mount if you are going to remove the actuator, as it will be set at some arbitrary position as it stands.
__________________
Llew is online now   Reply With Quote
Old 03-02-2007   #3
Llew's Avatar
...on the other hand, if you are able to screw/unscrew the actuator piston, you could leave it on, screw it in or out and refix it after centering the dish.
__________________
Old 04-02-2007   #4
izefisherman's Avatar
My System: Ku: 2.4m Aerial PFA / Invacom SNF-031, C: 1.2m Aerial PFA / MTI 15k, DM7020-S, DM500S, C-Tech 2100, VBOXII
If the actuator has no slack you can leave it on. Just use a 12V car battery charger to drive it to the desired position. That is what I did before I got myself a 36V positioner. Even though the motor has a rated voltage of 36V it will run nice and slow on 12V.
PS.
Swap + and - to change the direction of movement.
izefisherman is offline   Reply With Quote
Old 04-02-2007   #5
There is some slack and because of this the dish moves in gusts of wind. I've already found the satellite I'm looking for (Astra 2D) but I'm looking to solve the movement problem.
PS.
[IMG] code is Off
Forum Jump
