motorised dish | |
| Regular Member Join Date: 03-02-2007 Location: UK exeter
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 |
hi guys. i live in exeter uk i have a humax 2000 reciver can anyone put me right where to buy a dish and what size quality one at cheap price theres some on Ebay | ||
| | #2 | |||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! |
![]() Plenty to choose from too...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
| Nasty Dish Obsession Join Date: 01-06-2004 Location: Oxfordshire
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | The first question has got to be 'what is it that you intend to watch' ? When you have a clear idea of this then we can start the ball rolling. Rgds L.
__________________ I've got an inferiority complex, but it's not a very good one. | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | hi i want watch films sport football ect as much as poss later buy a cam thanks | ||
| | #5 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | A 1mtr dish would be a good start, Gibertini or Triax. L.
| | #8 | |||
| | #9 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Looks OK, the DG120 is a known motor and the 0.2 inverto is a good LNB. Dont know the dish however but as long as its not warped when it arrives then should be fine. Give us a shout on here when you're ready to do the install. Rgds L.
| | #10 | ||
| Regular Member Join Date: 01-01-2000 Location: Doghouse
| There are a few on Fleabay and the ones you are looking at seem to have pretty well most things. Forum sponsor has a couple worth a look:- http://www.dvb-shop24.net/index.php/...un2kqropic03u5 You might want to check if bracket and bolts included - dont think they are in the first one but if you ask they might be available at a small additional cost ...
__________________ I married Miss Right. I just didn’t realise her first name was always. | ||
| | #11 | |||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish |
| | #12 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | I agree ![]() L.
| | #15 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Got it tnx. Go with the Gibbi. L.
| | #16 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | OK WILL DO just keep looking at the triax is the gibe ok in high wind thanks for all you help because i have not got a clue | ||
| | #17 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | It's generally the motor and/or mount that suffer in really high winds. It would have to be exceptional to bend a small dish. L.
| | #18 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | THANKS ALL have orderd the gibertini dish ect wait for it come now here we go lol | ||
| | #19 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Oh no, another satellite monster is hatched.
__________________ | |||
| | #20 | ||
| My mate wants a dark grey Gibi dish with this motorised system ..he doesnt have Internet at the mo so I've emailed supplier on his behalf and cant get any answer - dunno if it is language prob as my question was in English and dealer appears to be in Germany.. Does anyone know if the suffix #DG = dark grey/charcoal for the Gibi from this retailer please?
| | #21 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | yes i would think so digdog if you live near bristol hisat sell gibertini dishes so you could go and collect it | ||
| | #24 | ||
| Thanks Wod - seems server was down in Germany - I'm about 200 miles north of Bristol so order now placed wih dvb. Their code #DG does mean dark grey. So my mate and I will have identical systems when it comes and I get it set up - cant have him bragging he has a bigger/ better one than me... ![]() den123 - cheapest option is to get a mate who has a meter to lend you a hand. But if you get an el cheapo meter it should be ok for initial setup - but take it out and use the readings from your receiver when you do the final tweaking as the meter chops signal down something terrible - go for max quality for best performance - it is all good fun - honest!
| | #25 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | my dish came today put it all together before wife comes from work lol will try fix the wall bracket tomorrow then take it from there so may need a lot of help later stay on line guys when iam ready for your help thanks den anyone fancie giving me there phone number in case i get stuck thanks | ||
