Monoblock and 4 way switch.
Thread Tools Display Modes
Old 06-02-2007   #1
My System: TM 1500 Super T-Rex 4.6 K£ Mr 90cm
Good Morning,
Recently I purchased a D500s as a second receiver and wanted to link it to my main motorised dish. Having asked on here as to the possibility of running the 2 receivers in to the same dish I came to the conclusion that unless I wanted to use a remote extender I would have to go down the multi-LNB route.
I have now purchased a quad output Invacom monoblock and this is now lined up on the motorised system; I have no problems with the receiver attached to the motor as it is set to act as a single LNB, however on the second receiver I seem to be having problems.
I want to connect the second receiver to both the SKY minidish and directly to the monoblock (this way I can leave the dish * 19e and use the monoblocks internal diseqc to switch between 19 and 13e). The way I have done this is to connect the SKY dish and the monoblock feed in to a 4-way diseqc switch. The receiver attached to the switch seems to randomly decide, to work for a short period or fail altogether.
My question is. Am I on the right track here and have a faulty diseqc switch or will this setup not work at all.I have tried all possible configurations in the setup menu with very unreliable results. I have ordered a new 2 way switch just in case.
Any help will be appreciated especially if you’ve tried this setup yourselves and can point me in the right direction.
drsprout is offline   Reply With Quote
[IMG] code is Off
Forum Jump
