satelite meter | |
| Regular Member Join Date: 03-02-2007 Location: UK exeter
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 |
whats the best sat meter i should look for setting motorised dish up thanks | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | depends i bought a digisat pro meter for 40quid and it was excellent, those beeper things are crap | ||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! | As wod says - depends on your budget. I set mine up using one of the 'beeper' things. Cost a fiver and worked OK for me. | ||
| Regular Member Join Date: 08-02-2005 Location: Lot, Dordogne, Correze border.
My System: Dbox + Skystar2, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | If you're not doing it professionally then why not splash out 6 quid and get an analogue meter. | ||
| | #5 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | think i will do that or if anyone lives in exeter they can give me a hand small fee thanks | ||
| | #6 | ||
My System: Dbox + Skystar2, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | Something like Ebay | ||
| | #7 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | IS THAT METER OK BECAUSE I HAVE NOT GOT A BLOODY CLUE HA HA HELP i am looking for a digisat pro cheap they look good and would be easy for me to set the dish up I THINK | ||
| | #8 | ||
| Member Join Date: 05-04-2006 Location: South Africa
My System: Delsat DSR5500, Radix DT100, Dreambox 500 & Multichoice Receivers plus Compro sat card Dishes 1M, 80cm & 50cm. USB Stick for DTT (But no transmissions in Cape Town yet!!!) | I use a beeper here in South Africa as anything else was prohibitively expensive, and it works fine. | ||
| | #9 | ||
My System: Dbox + Skystar2, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | Exeter is at about 3.5 degrees West, so with your dish at the 0 degree position set your reciever to recieve France 2 on 11590V 20000 2/3 (this is on Atlantic Bird at 5 West). Align the dish , peaking it up with the analogue meter. Give the dish a nudge a couple of degrees to the left (on the mounting). You may need to increase the elevation a touch so that 5W is still on the arc. With a bit of luck you should be able to send the dish around to 28.2 East and 30 West to tweak your alignment. | ||
| | #10 | |||
| Super Nutty Mod Join Date: 03-10-2003 Location: Essex
My System: Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka ! |
It's the same one that I use and it does me alright, though I must admit I would prefer something more accurate when doing the finally positioning.
__________________ If anyone wishes to copy the Madeleine appeal please feel free to do so. ![]() | |||
| | #11 | ||
My System: Dbox + Skystar2, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | The main things to get right for a good installation are that the mounting pole is perfectly vertical, the dish is pointing in the right direction, and that the inclination/declination angles are set correctly. | ||
| | #13 | ||
| Member Join Date: 14-02-2007 Location: Spain, Xabia area
My System: 2.4 port. dish invacom twin cyprus feedhorn into pace 2600 99.9% of channels 99.9% of the time !!! | Hi, If you can afford it the Horizon HDSM is an serious bit of kit. I have two with special hex files for BBC1, 2, ITV, 4 & 5 and it just pee's over those crapy buzzer things. They are easy to use and you can download from their site almost any sat/transponder or they will write you a prog. They are also go for vsat stuff which i do loads. | ||
