Dish install help please | |
| Regular Member Join Date: 03-02-2007 Location: UK exeter
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 |
i guys anyone in exeter can help me put up motorised dish up and set it up the more i read about setting dish up the more i start going pale lol like i said iam new learning | ||
| Specialist Contributor Join Date: 06-08-2004 Location: Down South
My System: Dreambox 7020si, Dreambox 7000s,DS v3.6,PB Enigma 2.0.1, Nabilo v0.8,SIF Team v1.8.9,pli Helenite,EDG v4.0 Netgear adsl router, 98cm Funkee on Diseqc motor, Maintaining Hummy 5400 for the old man! | Hi den123, Do not be put off by thinking it is over technical, If you can put a shelf up you can put a dish up. Honest, have a look around the site and if you have problems ask for help. We were all where you are at some point but you will feel more satisfaction doing it yourself | ||
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I agree, it isn't difficult, but you do need to be methodical. Follow the procedure exactly, and you will have your system up and working in a day.
__________________ | |||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | thanks guys will give it a go just all of you stay on line when i get started lol | ||
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | How high up is it going to go den?
| | #6 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | hi mate we in a bungalow so to just clear the roof at back of house about 12ft high thanks | ||
| | #7 | ||
dish came today have put it together in the liveing room before the wife comes from work lol lol no got to fix bracket outside tomorrow if the weather is not raining if i get stuck is there anyone i can phone in the uk thanks guys | ||
| | #8 | ||
hi guys can anyone help me i live in exeter ex6 7tp what settings will i have to set the dish at any help please new here | ||
| | #9 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | For which satellite? Or is it a motorised system? Why not put your equipment in your profile?
| | #11 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Your elevation figure on the motor will be 50.6, your longitude is 3.5 degrees West, so you can set up your due South on either 1W or 5W, but you will need to offset the motor by a couple of degrees whichever you select.
| | #12 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | thanks mate what do you meen offset the motor by couple of degrees thanks | ||
| | #13 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | If you are using a receiver with USALS, then you set the motor to zero or refence point, then set up your coordinates in the receiver, then tell it to go to either 5W or 1W, whichever you decide to use as your reference satellite.
| | #14 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | thanks mate is there any chance doing a step by step guide as what to do from start to finnish iam a bit slow thick. lol i have a humax 2000 reciver hopeing to start putting the dish up today if weather is ok got get a mast pole first thanks mate | ||
| | #15 | ||
| Donate to this board Join Date: 05-09-2006 Location: So called capital of Suffolk, UK.
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband. | If the scale on the side of your motor is marked Latitude set it to 50.6. If the scale is marked elevation set it to 90 minus 50.6 ie 39.4. PR | ||
| | #16 | ||
| Super Nutty Mod Join Date: 03-10-2003 Location: Essex
My System: Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka ! | Look at the "sticky threads" at the start of this section i.e. My Motor Set-up Tutorial by Longstockings or Set-up The Dish by T24 and they tell you how to do it.
__________________ If anyone wishes to copy the Madeleine appeal please feel free to do so. ![]() | ||
| | #17 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | hi how do i get the .6 you say 50.6 latitude the markings on the motor go in 1s up to 65 thanks | ||
| | #18 | ||
| Member Join Date: 16-09-2006 Location: Wolverhampton
My System: Motorised 1.2M Fibo looking between 45E - 60W, TM9100 Receiver running EDG-Nemesis 3.2 in flash | Just set it to midway between 50 and 51, that'll be close enough. I don't think that the 0.1 deg will make any difference. Believe these guys when they tell you it's not that difficult. I put up my very first motorized system a couple of months ago following the stickies at the top of the thread and within 4 - 5 hours was up and running. Good luck with it. | ||
| | #19 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | have set the longetude to 50.6 what settings do i have to set the dish setting on thanks | ||
| | #20 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | It should tell you that in your motor manual, can you put your exact setup, with a bit of deatil in your profile, then we will all know what we are taling about. Make and model is motor Make of Dish Type of bracket Model of Humax You really don't need to set the angle of the dish, that is done when you try to find the due South satellite. PS. 50.6 is your latitude.
| | #21 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | i see got you thanks will try put dish up tomorrow if its not pissing down got soaked today putting wall bracket on the wall thanks to you all for your help den | ||
| | #22 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | cool make sure the mount is 100% level before you fit the dish on it | ||
| | #23 | ||
hi guys. have put my dish up today mortorised bit windy but got it up right now my problems start have set the lattitude setting on the motor that you gave me 50.6 have pointed the dish south can you please tell me what i have to do nowto find a satelite do i move the dish manuay or by the reciver bit lost now what satilite should i set it up to feq ect anyone got a humax 2000 reciver spent most afternoon trying to see how it works thanks guys stuck now | ||
| | #24 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | As said in a couple of the sticky threads, you need to move the whole assembly on the pole for the azimuth and the dish elevation only, to find your due South satellite, whichever one you decide to go for.
| | #25 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | can you explane in engish mate bit thick here lol bit at a time dont understand this azimuth due south satelite thanks den | ||
