satellite signal angle ?
Thread Tools Display Modes
Old 09-02-2007   #1
My System: dreambox 7000s w/160 Gb hdd superjack dg120 diseqc motor lidl 80cm dish and lnb
gonna put a setup a motorised system with 88cm dish up for a mate. he has some tall trees at the end of his garden. so i need to know roughly at what degree to the horizon the signals from satellite come in at.if you know which satellite has the lowest angle would be even better. i can then work out will the trees block the signal as they are still growing.
kitoog is offline   Reply With Quote
Old 09-02-2007   #2
rolfw's Avatar
download the Swedish Microwave calculator , input your coordinates, then the location of the various satellites in the arc, you can get these from _www.lyngsat.com. It will give you every elevation on the arc.
__________________
Rolf
Donate
Old 09-02-2007   #3
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
It's getting quite close now to when the sun's azimuth equal to the satellite's azimuth is zero degrees - a couple of weeks hence ( when you can see it ), so the sun will be following the satellite arc.
Click on 'Antenna Look Angles' here -
http://www.satellite-calculations.com/
And enter your coordinates for the satellites you are interested in.
__________________
Llew is offline   Reply With Quote
Old 09-02-2007   #4
cheers, nice program, just what i needed.
Old 09-02-2007   #5
Donate to this board
Park Royal's Avatar
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
sun outage
You can also use this link, http://www2.ips.gov.au/Satellite/3/1.
Or this one, http://www.globaltt.com/index-en.htm...larOutage.aspx.
PR
Park Royal is offline   Reply With Quote
[IMG] code is Off
Forum Jump
